Gas consumption in energy panel not working
Hi all !
I had successfully plugged a zigbee button to my gas counter following this guide :
So i have a input_number increasing each 10L and a sensor that divide this value by 1000 to convert in m³ for the volume.
Here is my configuration :
  • The input_number :
gas_counter:
  min: 0
  max: 100000000000
  icon: "mdi:gas-station"
  mode: box
For information only, the input_number is updated with nod red to avoir false counter when HA restart :
  • The sensor :
  sensors:
    gas_volume:
      friendly_name: "Gaz Volume"
      unit_of_measurement: 'm³'
      value_template: "{{ states('input_number.gas_counter') | int / 1000 | round(3) }}"
      device_class: gas
      # state_class: total
→ sensor is working BUT the state class is not ( HA refuse to restart, unsupported state )
  • Finally the utility meter :
# gazpar
utility_meter:
  daily_gas_volume:
    source: sensor.gas_volume
    cycle: daily
  weekly_gas_volume:
    cycle: weekly
  monthly_gas_volume:
    cycle: monthly
  yearly_gas_volume:
    cycle: yearly
The result :
In energy tab :
Don’t know WHERE and WHAT is sensor.gas_consumption_index_kwh cause i can’t found it anywhere in all my config file ( HA created this one automatically ? no existing in dev tools too btw )
→ Problem none of my sensor is accepted in energy panel. And why the state classe is unsupported ?
Any help would be gratefully appreciated ! Thk !
no one :frowning: ?
Shouldn’t your state class be ‘total_increasing’?
Sadly, i can’t :
The system cannot restart because the configuration is not valid: Invalid config for [sensor.template]: [state_class] is an invalid option for [sensor.template]. Check: sensor.template->sensors->gas_volume->state_class. (See ?, line ?).
  sensors:
    gas_volume:
      device_class: gas
      state_class: total_increasing
I think it’s because you’re using the legacy template sensor format (pretty sure it can’t handle state class). Try the current one:
Thanks for your support but…
EDIT : sorry, still legacy format…
Did it !
This is the correct syntax :
  sensors:
    gas_volume:
      unit_of_measurement: "m³"
      device_class: "gas"
      attribute_templates:
Thanks !
