Since 19 december 2023 my gas_consumption sensor is not working correct anymore.
I’m using influx db and grafana, and since above date the readings are all 0.
It might be difficult to see, but there are in fact entry’s after the 19th on the correct times, however they are all 0
If I go to the entity itself and view the history I can see that it is updating as normal.
Also the energy panel is showing the normal values.
Any idea why the sensor appears to be working correct but is not putting the correct data in the database?
So far I have not found any other sensors that appear to be off.
What can I do to troubleshoot this?
