Did someone find a way to read data/integrate into Home Assistant the Gas Meter model EG4 EV from Meter Italia?
Thanks in advance
Thanks in advance
I’m interested as well.
Just started ì looking for a solution…has anyone made it work?
Maybe this can help
did you try it?
the optical interface should be a couple of ir emitter/receiver, but i fear the application layer (i.e. a password needed to start communication?)
Ciao, sei riuscito a trovare una soluzione? Sono anche io in cerca di un modo per leggere i dati e trasmetterli ad home assistant.
Grazie
In realtà non ci ho neanche provato
Mi accontento di calcolare il consumo del gas in base alle ore di accensione del termostato (Netatmo)… ed è piuttosto preciso…
In un anno ha sbagliato meno del 5%
How do you do that? Can you share your template?
Here it is…
climate.casa is the Netatmo thermostat entity id
template:
- sensor:
- name: caldaia
state: "{{state_attr('climate.casa','hvac_action')}}"
- sensor:
- name: "Caldaia Consumo Gas"
state: "{{states('sensor.caldaia_ore') | multiply(1.75) | round(2, default=0)}}"
unit_of_measurement: "m³"
state_class: total_increasing
device_class: gas
Great ideia, do you use the consumption reference in the manual of the heater? I think I need to adjust every day until get a good number, this will help a lot!
no… I calculated it based on my statistic data I had from the past (many years) … monitoring both gas consumption (from billing) and running duration (from Netatmo cloud data) …
So it is quite precise…
Hi Stefano, I have the same thermostat and I just added your code. I can see the climate.casa switch between idle and heat, but sensor.caldaia_ore always remains 0. Am I missing something? Thanks in advice!
Forgot to mention you need to create helpers with Utility meter…
Stefano I’m sorry but brand new at theese congurations. Could you please specify also the helpers I need to create? If I get something that works maybe I will undestand something more about HA environment. Thanks in advance.
io ho parlato con un ing. di unareti. La porta ottica dei G4 è disattivata perchè… boh non so perchè. ma dopo averci provato e riprovato mi sono fidato della rispostaccia e mi sono messo l’anima in pace. peccato
