Gas sensor shows up in eneregy dashboard but reports zero
I have an ESP monitor my gas meter with this config.
# gas meter
  - platform: pulse_counter
    pin: 21
    update_interval : 60s
    filters:
      - lambda: |-
          static float total_value = 0.0;
          total_value += x * 0.01;
          return total_value;
    unit_of_measurement: "m³"
    accuracy_decimals: 2
    icon: 'mdi:fire'
Various tips on the forum suggest to add the device and state classes, so my customize.yamlreads
sensor.gasverbrauch:
  device_class: gas
  state_class: total_increasing
All ends up in HA, where the developer tools show
unit_of_measurement: m³
friendly_name: Gasverbrauch
icon: mdi:fire
device_class: gas
Sadly, the energy dashboard refuses to show anything other then … zero. I’m running core-2021.9.7 if that matters. Anyone any idea?
Hi
Look at mine
You have to add a way to cumulate your counter
# Consommation gaz
    pin: GPIO26
    name: "Gazpar debimetre"
#    name: "Gazpar TIC"
    state_class: measurement
    internal_filter: 13us
    update_interval: 1s
    filters:
      - lambda: return (x * 10); # 1 impulsion = 10 l
# Consommation Total gaz Journalière
  - platform: total_daily_energy
    name: "Gazpar Conso Gaz du Jour"
    device_class: "gas"
    power_id: gazpar
    accuracy_decimals: 3
    filters:
      - lambda: return (x * 0.001*60);
how did you manage to add this to your gasmeter energy dashboard?
Mine refuses to add my gas_consumption sensor:
configuration.yaml:
# For the gas usage sensor
    sensors:
      gas_meter:
        friendly_name: Gas Zähler (gesamt)
        icon_template: "mdi:counter"
        device_class: gas
        value_template: "{{ states ('counter.gas_zahler_rohwerte') | float(0) * 0.01}}"
and (in the customize section of configuration.yaml
    # gas energy sensor
    sensor.gas_meter:
      device_class: energy
      last_reset: '2022-09-27T00:00:00.000000+00:00'
My energy dashboard refuses to add my gas meter:
EDIT:
Actually I can add the gas_meter mentioned above (does not show data).
But I cannot add the monthly / daily gas consumption based on this sensor (Utility Meter)
Well, I didn’t add sensor.gas_verbrauch_tag to the energy dashboard.
I added the sensor that is defined for the ESP (sensor.gasverbrauch), see home-assistant/gas4.yaml at main · swa72/home-assistant · GitHub. Additionally, my customize.yaml includes
  device_class: gas
Thanks,
your “customize” section is in my configuration.yaml as well (changed energy to gas like in your case).
it still does not show data.
