Gathering data from different sensors
I use ESP-Now to collect data from various sensors. The data is sent in JSON format and is of the form:
Sensor 1
  "MAC": "5C:CF:7F:8E:32:E4",
  "Sensor": "TMP102",
  "Temperature": 24.06,
  "Voltage": 3.21
Sensor 2
  "MAC": "5C:CF:7F:8E:31:E1",
  "Sensor": "BME280",
  "Humidity": 54.03,
  "Pressure": 1000,
  "Voltage": 3.14
One microcontroller is directly connected to the raspberry pi and collects data from these sensors and sends it to the home assistant via the serial port. How can I assign the received data to different sensors in home assistant?
Can you change your message format?
If not, it is going to be difficult to tell which message is which using the serial sensor integration:
If you sent something like this instead:
  "5C:CF:7F:8E:32:E4": {
     "Sensor": "TMP102",
     "Voltage": 3.21
It would be a lot easier.
As long as the top level key is unique (in this case I’m using the MAC) you can use anything. e.g. you could use the sensor name TMP102 instead, as long as it is the only sensor with that name. That top level key is what we could use to identify the data.
e.g. for my example above:
  - platform: serial
    serial_port: /dev/ttyUSB0
    baudrate: 9600
    sensors:
      tmp102_temperature:
        friendly_name: TMP102 Temperature
        unit_of_measurement: "°C"
        value_template: '{{ states("sensor.serial_sensor")["5C:CF:7F:8E:32:E4"]["Temperature"] }}'
      tmp102_voltage:
        friendly_name: TMP102 Voltage
        unit_of_measurement: "V"
        value_template: "{{ states("sensor.serial_sensor")["5C:CF:7F:8E:32:E4"]["Voltage"] }}'
Thanks, I changed message format to the one you proposed:
     "Sensor": "TMP102",
     "Voltage": 3.21
I am able to receive the message with minicom but in home assistant I get this error:
TemplateError(‘UndefinedError: ‘str object’ has no attribute ‘5C:CF:7F:8E:32:E4’’) while processing template ‘Template("{{ states(“sensor.serial_sensor”)[“5C:CF:7F:8E:32:E4”][“Temperature”] }}")’ for attribute ‘_state’ in entity ‘sensor.tmp102_temperature’
6:38:11 PM – (ERROR) Template - message first occurred at 6:38:11 PM and shows up 2 times
Error while processing template: Template("{{ states(“sensor.serial_sensor”)[“5C:CF:7F:8E:32:E4”][“Temperature”] }}")
6:38:11 PM – (ERROR) helpers/template.py - message first occurred at 6:38:11 PM and shows up 2 times
Edit: there’s an error in my second value_template, the leading double quote should be a single quote. Also…
Ugh. States are always stored as strings. As the serial sensor is not capable of storing the received json in an attribute (which can be any type, not just a string like states) we need to convert it back to json. Try this
    sensors:
      tmp102_temperature:
        value_template: '{{ (states("sensor.serial_sensor")|from_json)["5C:CF:7F:8E:32:E4"]["Temperature"] }}'
      tmp102_voltage:
        value_template: '{{ (states("sensor.serial_sensor")|from_json)["5C:CF:7F:8E:32:E4"]["Voltage"] }}'
We may still have an issue when the serial sensor state does not contain the payload we are looking for. But let’s get this bit working first then trap that error later.
Ok, I’m sure there’s a better way, but I’d go about this with the new template integration and the shortest payload possible.
Change your payload back to this:
  "Sensor": "TMP102",
  "Voltage": 3.21
Then make your sensor
  - platform: serial
    baudrate: 9600
Then your new template
template
  - trigger:
        value_template: >
          {{ (states('sensor.serial_sensor') | from_json).MAC | default == '5C:CF:7F:8E:32:E4' }}
      - unique_id: tmp102_temperature
        state: '{{ (states("sensor.serial_sensor")| from_json).Temperature }}'
      - unique_id: tmp102_voltage:
        state: "{{ (states("sensor.serial_sensor")| from_json).Voltage }}'
  - trigger:
        value_template: >
          {{ (states('sensor.serial_sensor') | from_json).MAC | default == '5C:CF:7F:8E:31:E1' }}
      - unique_id: bme280_temperature:
      - unique_id: bme280_voltage:
But you’ll have to send a payload of {} between each send because 2 payloads in a row with an identical mac will not trigger an update.
I’m beginning to wonder if home assistant receives data through the serial port at all. On my raspberry pi I run home assistant in docker container. Do I need to somehow activate the serial port when home assistant runs in docker? I receive data in correct format (checked with minicom) when I connect directly to my raspberry pi via SSH.
Now I see these errors:
Logger: homeassistant.helpers.event
Source: helpers/template.py:391
First occurred: 8:11:04 PM (2 occurrences)
Last logged: 8:11:04 PM
Error while processing template: Template("{{ (states(“sensor.serial_sensor”)|from_json)[“5C:CF:7F:8E:32:E4”][“Temperature”] }}")
Error while processing template: Template("{{ (states(“sensor.serial_sensor”)|from_json)[“5C:CF:7F:8E:32:E4”][“Voltage”] }}")
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 389, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1358, in _render_with_context
return template.render(**kwargs)
File “/usr/local/lib/python3.8/site-packages/jinja2/environment.py”, line 1304, in render
self.environment.handle_exception()
File “/usr/local/lib/python3.8/site-packages/jinja2/environment.py”, line 925, in handle_exception
raise rewrite_traceback_stack(source=source)
File “”, line 1, in top-level template code
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1310, in from_json
return json.loads(value)
File “/usr/local/lib/python3.8/json/init.py”, line 357, in loads
return _default_decoder.decode(s)
File “/usr/local/lib/python3.8/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File “/usr/local/lib/python3.8/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 505, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 391, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:72
Integration: Template (documentation, issues)
  • TemplateError(‘JSONDecodeError: Expecting value: line 1 column 1 (char 0)’) while processing template ‘Template("{{ (states(“sensor.serial_sensor”)|from_json)[“5C:CF:7F:8E:32:E4”][“Temperature”] }}")’ for attribute ‘_state’ in entity ‘sensor.tmp102_temperature’
  • TemplateError(‘JSONDecodeError: Expecting value: line 1 column 1 (char 0)’) while processing template ‘Template("{{ (states(“sensor.serial_sensor”)|from_json)[“5C:CF:7F:8E:32:E4”][“Voltage”] }}")’ for attribute ‘_state’ in entity ‘sensor.tmp102_voltage’
Change your message format back and try Petro’s solution. But before making the template sensors just make the serial sensor and check that its state changes when you send a message. You can check its state in the Developer Tools / States menu.
I am able to receive the data without template sensors. I will try @petro solution.
Now I got:
  • Invalid config for [template]: [tmp102_temperature] is an invalid option for [template]. Check: template->sensor->0->tmp102_temperature. (See /config/configuration.yaml, line 203).
  • Invalid config for [template]: [bme280_temperature] is an invalid option for [template]. Check: template->sensor->0->bme280_temperature. (See /config/configuration.yaml, line 216).
You should check out the docs for the template section. I adjusted (edited) my example and it should be correct now. I shouldn’t have copied and pasted. Either way, formatting issues will be highlighted by looking at the template examples in the docs.
I am still not sure if I put the code in right place. Right now I put it into my /config/sensors.yaml file. In order to save the file I had to remove the “template”. So my file looks like this:
- platform: serial
  serial_port: /dev/ttyAMA0
  baudrate: 9600
- trigger:
      value_template: >
      state: '{{ (states("sensor.serial_sensor")| from_json).Voltage }}'
- trigger:
      value_template: >
      name: BME280 Temperature
But when I check the configuration I get the following error:
Configuration invalid
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 12). Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 12).
You’re using petro’s example which is a Trigger-based Template Sensor and must be defined under the template domain (not the sensor domain). You have added it to yoursensor.yaml file which means you have put it under the sensor domain (which is invalid).
Remove the Trigger-based Template Sensors from that file and add them to your configuration.yaml file under the template domain.
template:
- trigger:
      value_template: >
- trigger:
      value_template: >
Alternately, you can add them to a new templates.yaml file and then add the following to your configuration.yaml file:
template: !include templates.yaml
Thanks @123 I moved template into separate templates.yaml file and included it in configuration.yaml. The configuration is again valid but I still get errors:
Error while processing template: Template("{{ (states('sensor.serial_sensor') | from_json).MAC | default == '5C:CF:7F:8E:32:E4' }}")
Error while processing template: Template("{{ (states('sensor.serial_sensor') | from_json).MAC | default == '5C:CF:7F:8E:31:E1' }}")
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 389, in async_render
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1358, in _render_with_context
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1304, in render
  File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 925, in handle_exception
  File "<template>", line 1, in top-level template code
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1310, in from_json
  File "/usr/local/lib/python3.8/json/__init__.py", line 357, in loads
  File "/usr/local/lib/python3.8/json/decoder.py", line 337, in decode
  File "/usr/local/lib/python3.8/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 505, in async_render_to_info
  File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 391, in async_render
Seems like the error message is complaining about not getting a value where it was expecting one.
Just a guess but if the Serial Sensor’s value fails to be converted into JSON then it might generate that error (for example, if the sensor has no value or a non-JSON value).
Possibly due to this?
Sent this instead?
{ "MAC": "0" }
I carried out the following test. I disconnected the microcontroller sending data through the serial port and restarted home assistant. In the log the same error appeared as displayed above. I then connected the microcontroller and started sending data and at this time started home assistant. The same errors and new warning appeared:
Error evaluating 'template' trigger for 'Trigger Update Coordinator': JSONDecodeError: Expecting value: line 1 column 1 (char 0)
It looks like home assistant is not refreshing the serial port when new data arrives. The port is pulled on startup, when there is no data yet (then errors occur), and then when data arrives it is not refreshed. This is also confirmed by the fact that I have to press the refresh button to get data in Developer Tools → states
It appears that refreshing the serial sensor is a known problem:
Then alter the template trigger to check for data before serializing
I’m not sure that changing the trigger will solve the problem. It seems to me that the problem is with the serial port refreshing. I added new line after sending the data as suggested by @macle here:
But it does not work for me. This not working behavior is also confirmed by @Tom92. I have also tried many different combinations, none of which refresh the data:
Serial2.println((const char*)data);
Serial2.println();
Serial2.print((const char*)data);
Serial2.println();
Serial2.print('\n');
Serial2.print('\r');
Serial2.print("\r\n");
Serial2.print("\n");
Are you recompiling your code?
