Gattlib==0.20150805
I’m having some trouble installing the above or rather HA is :frowning: I’m on an RPI 3 running Stretch on AIO install of HA. HA can’t install gattlib and when I tried to install it manually it fails with some kind of internal compiler error. Has any got any ideas why it wouldn’t install?
TIA for any clues :slight_smile:
Edit : I’m running HA 56.2 tho’ this problem has been going on for a while now :frowning:
Edit: In the VE running command python show I’m running Python 3.5.3
There’s many possible issues, but if you don’t tell us the actual error it’s hard for anybody to help :wink:
IRRC when I last tried to diagnose the problem all the information it gave was that there had been an internal compiler error, however I will run it again and see if I can get anything more from it :slight_smile:
Collecting gattlib==0.20150805
  Using cached gattlib-0.20150805.tar.gz
Building wheels for collected packages: gattlib
  Running setup.py bdist_wheel for gattlib ... error
  Complete output from command /srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-yuwcluvo/gattlib/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpt3pe8r1fpip-wheel- --python-tag cp35:
  running bdist_wheel
  running build
  running build_ext
  building 'gattlib' extension
  creating build
  creating build/temp.linux-armv7l-3.5
  creating build/temp.linux-armv7l-3.5/src
  creating build/temp.linux-armv7l-3.5/src/bluez
  creating build/temp.linux-armv7l-3.5/src/bluez/lib
  creating build/temp.linux-armv7l-3.5/src/bluez/attrib
  creating build/temp.linux-armv7l-3.5/src/bluez/src
  creating build/temp.linux-armv7l-3.5/src/bluez/src/shared
  creating build/temp.linux-armv7l-3.5/src/bluez/btio
  arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-RUbMX3/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DVERSION="5.25" -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include -Isrc/bluez -I/usr/include/python3.5m -I/srv/homeassistant/homeassistant_venv/include/python3.5m -c src/gattservices.cpp -o build/temp.linux-armv7l-3.5/src/gattservices.o
  cc1plus: warning: command line option ‘-Wstrict-prototypes’ is valid for C/ObjC but not for C++
  arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-RUbMX3/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DVERSION="5.25" -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include -Isrc/bluez -I/usr/include/python3.5m -I/srv/homeassistant/homeassistant_venv/include/python3.5m -c src/beacon.cpp -o build/temp.linux-armv7l-3.5/src/beacon.o
  arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-RUbMX3/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DVERSION="5.25" -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include -Isrc/bluez -I/usr/include/python3.5m -I/srv/homeassistant/homeassistant_venv/include/python3.5m -c src/bindings.cpp -o build/temp.linux-armv7l-3.5/src/bindings.o
  arm-linux-gnueabihf-gcc: internal compiler error: Killed (program cc1plus)
  Please submit a full bug report,
  with preprocessed source if appropriate.
  See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
  error: command 'arm-linux-gnueabihf-gcc' failed with exit status 4
  Failed building wheel for gattlib
Ok, not seen that before.
Your install is ok? No issues with the power supply (sudo vcgencmd get_throttled shows 0x0)? Nothing else running that would be using up the RAM?
Install seems OK, HA uses 100 of one core 99% of the time.
sudo vcgencmd get_throttled shows…
throttled=0x50005
I will give another PSU a try :slight_smile:
Snapshot of ‘top’
                                                cpu   ram%
11161 homeass+  20   0  422116  87068  10244 S  98.7  9.2 295:23.79 hass
 4264 root     -81   0  118788   8868   6552 S   7.2  0.9   1:37.82 pilight-daemon
 3905 root      20   0       0      0      0 S   4.9  0.0   0:43.54 kworker/0:0
 6354 pi        20   0    8240   3360   2760 R   2.0  0.4   0:00.62 top
 2101 root      20   0  127148  28736   9560 S   0.7  3.0 146:48.75 node
    7 root      20   0       0      0      0 S   0.3  0.0  12:46.09 rcu_sched
   79 root      20   0       0      0      0 S   0.3  0.0  25:43.08 mmcqd/0
  773 influxdb  20   0 1082320 189884   7876 S   0.3 20.0 302:24.62 influxd
 2259 pi        20   0   11584   2040   1788 S   0.3  0.2   0:47.78 sshd
 2381 root      20   0       0      0      0 S   0.3  0.0   0:01.29 kworker/1:1
 3416 root      20   0       0      0      0 S   0.3  0.0   0:02.03 kworker/u8:1
    1 root      20   0   28200   4232   3252 S   0.0  0.4   1:32.91 systemd
influx seems to be the only user of a significant amount of ram.
You’ve certainly got a power issues there :frowning:
With another PSU I get 0x50000 so better I guess but not zero :frowning:
The bad news is, it’s bit 16 (the 1 of that 5) that indicates an under power situation. At least it’s now not actively reporting it.
Check the micro USB cable, it could be part of the problem.
