Gauge Card mirroring
Is it anyhow possible to mirror a gauge card so that zero is on the right side and the needle goes to the left?
Try card-mod, some “transform” functions… You will have to learn css.
Alternatively - use a “mirrored” entity (example: if a source entity =33%, then a “mirrored” entity =67%); but seems that you need to show an original value…
Card-mod:
    card_mod:
      style:
        ha-gauge $: |
          .gauge {
            transform: rotateY(180deg);
Example:
type: vertical-stack
cards:
  - type: entities
    entities:
      - input_number.test_level_1
  - &ref_gauge_card
    type: gauge
    entity: input_number.test_level_1
    needle: true
    segments:
        color: green
        color: orange
        color: red
  - <<: *ref_gauge_card
    card_mod:
      style:
        ha-gauge $: |
          .gauge {
You’re estimation is absolutely correct! I want to show the sun elevation on the gauge card. When I’m sitting in front of my computer or in the garden I always lock to the east. So the sun is on the right hand. Showing the angle of the sun from right to left and the angle of my PV-Panels from left to right is a correct illustration of the reality.
Thanks for the solution. The CSS instruction is as easy as always - as long as you know the statement(s) to use …
Perhaps same is for everything)))
I am familiar with CSS - and I could have asked Chattie to help me find the statement. But discussing it here gives a value for everyone who will have the same problem in future :innocent:
