Since upgrading to HA 2021.12.1 my gauge cards are missing a needle on the iOS mobile device.
On Chrome / Windows 11 the needle is present
The same display on iPhone 11 Pro with IOS 15.2 and latest HA mobile app version:
Before HA 2021.12.1 no needles were missing in the mobile client.
Here is the YAML code for the first three gauges:
type: grid
cards:
- type: gauge
entity: sensor.meter_electricity_currently_delivered
min: 0
max: 3000
needle: true
- type: conditional
conditions:
- entity: sensor.wf_uv_index
state_not: '0'
card:
type: gauge
min: 0
max: 10
severity:
green: 0
yellow: 5
red: 7
unit: ' '
needle: true
- type: gauge
min: 0
entity: sensor.wf_illuminance
needle: true
max: 160000
square: true
columns: 3
Does anyone have tips how I can get the needle back?
I have the same problem. But I found that it’s only a problem on the newly updated iOS device with iOS 15.2. On the older (15.1) iPad it’s works as before. So maybe it’s related to iOS version and not HA version?
Good point Mike!
After your post I tried the page on an iPhone 6s with iOS 15.1 On the iPhone 6s everything looks like it should be. The needles are present in iOS 15.1
Now, where can I enter a request so that somebody can take a closer look?
I found a page where somebody is reporting something similar
opened 01:05AM - 14 Dec 21 UTC
### The problem
Gauge card UI bug. Needle doesn't display correctly, entire U… I is just buggy.
y
### What version of Home Assistant Core has the issue?
core-2021.12.1
### What was the last working version of Home Assistant Core?
core-2021.11.7
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
I will add a link to this discussion on that page.
WallyR
(Wally)
December 14, 2021, 12:56pm
5
Try to clear your browser cache while you are on another webpage.
The missing needles happen when I am using the HA iOS Mobile app and not in a browser.
Your suggestion inspired me to do the following:
start the HA mobile app
in Configuration / Companion App / Debugging select “Reset frontend cache”
stop the HA Mobile App
start the HA Mobile App.
Unfortunately the needles are not displayed on the screen.
WallyR
(Wally)
December 14, 2021, 2:16pm
7
Ok, good that you check that in the mobile app too, then the developers can rule that out
oakman
(kraiwut)
December 14, 2021, 3:28pm
8
After update my iPhone8 with iOS 15.2. I’m facing this problem too.
Same here.
Gauge card is misaligned
Ios15.2 (before it was ok)
GD85
December 15, 2021, 7:03pm
10
I have to same after upgrading to IOS15.2.
Reinstalling the app was not a solution…
Same thing on Mac OS Monterey 12.1 in both Safari and the HA Companion App. But not in Chrome or FireFox.
Looks like a change in Apple’s WebKit is causing this.
MHerweijer
(M Herweijer)
December 16, 2021, 9:28am
12
Same issue here. iOS 15.1 works fine. iOS 15.2 shows misaligned gauges
huu
December 18, 2021, 10:17am
13
yep… Just upgrade to ios 15.2 broke the gauges. on both browser and mobile apps, first thought it safari issues downloaded chrome on iphone, still the same.
MHerweijer
(M Herweijer)
December 19, 2021, 7:56am
14
iOS HA app update 2021.12 does not solve the issue unfortunately
AdriedeRegt
(Adrie de Regt)
December 21, 2021, 6:28pm
15
Same here, happened after update iOS to 15.2
Adrie de Regt
linickx
(Nick)
December 28, 2021, 3:43pm
16
+1 - Broken after upgrading to IOS15.2. As well as the frontend issue linked above, this one is also open for the IOS App: Gauge not displayed properly · Issue #2002 · home-assistant/iOS · GitHub
psu1989
(Psu1989)
December 29, 2021, 12:34am
17
Happens on Macbook Pro Monterey and the Home Assistant app but is ok in Chrome.
hesspoint
(Hannes)
January 16, 2022, 9:13am
18
Can confirm. Issue happens on iPhone, iPad, Mac in the HA app. All devices on 15.2 and latest Monterrey
snhnic
(Snhnic)
January 21, 2022, 2:34pm
19
Still no luck? Had the update and needle as colors miss lined
e-raser
January 21, 2022, 4:12pm
20
Yes, still no progress on this. I think the GitHub PR has some issues. Hoping for 2022.2 …
Meanwhile I started to switch over to custom:bar-card because this broken gauge view is just horrible after so many weeks.
