Gauge Card Pro 🌈
Inspired by the idea to be able to recreate the Home Assistant native Energy Gauge Cards I created Gauge Card Pro. Built on top of the Home Assistant Gauge card, but with many more features and beautiful look-and-feel!
  • :rainbow: Native gradient support for segments
  • :victory_hand: Two gauges in one
  • :hammer_and_wrench: Use templates for the majority of the fields
  • :artist_palette: Every element in the card can have its colour defined. This can be a single colour or two colours for light- or darkmode. Of course, allows templating!
  • :men_holding_hands: Set value and value_text independently
  • :eyes: Two labels underneath the gauge
  • :sparkles: Additional icon indicator next to the gauge
  • :artist_palette: Automatic color interpolation for severity gauges
  • :face_in_clouds: Native ability to hide the background
Basic customization examples
Advanced customization examples
Install
Gauge Card Pro :rainbow: is available in HACS → Link to HACS: Repository – My Home Assistant
Checkout this awesome post by @Chykan that explains the difference between the color handling for non-gradient and gradient segments:
https://community.home-assistant.io/t/gauge-card-pro/881211/59
v0.7.0 - More color magic! :magic_wand:
This release introduces the color_interpolation option for both the main and inner gauge. This setting will take over all the color magic you had to do by hand by interpolating a color between your segment steps!
These gauges are created with the following code. The color magic is done using color interpolation!
type: custom:gauge-card-pro
color_interpolation: true
segments:
    color: var(--success-color)
    color: var(--error-color)
inner:
  segments:
Very nice! I would love to see the code for the 3rd gauge in the advanced customization examples, for temp&humidity, please.
Should be something like this:
Yeah! Thanks for that! I’ve been looking for a decent gauge card for ages… all existing cards (canvas, horseshoe…) are old and not maintained anymore, so it’s only a matter of time when they will ā€œdieā€. What i miss most on HA’s built-in card is templates, and lack of them makes it pretty much useless (for me).
A couple of suggestions, if they are doable:
  • is it possible to change text size?
  • some sort of scale implementation would be good perhaps ?
Thanks for your feedback!
Would you mind making an issue at GitHub Ā· Where software is built for the text size? The texts inside the gauges already have auto-scaling, so I guess it’s the texts below the gauges you are after right?
Also for ā€œsome sort of scale implementation would be good perhapsā€, could you also make an issue explaining your wish? Right now I don’t really understand what you are after :slight_smile:
will do…
EDIT: now i came to the fact that text is auto-scaled… it’s ok for me, i don’t need more.
Ah, it’s just a thought… something similar like ā€œcanvas gauge cardā€ has:
or this one, just with numbers instead of icons:
(on the other hand, i’m not sure what’s better looking - with or withoug scale…)
I kinda see where you wanna go with that. However, I don’t feel that fits in my vision of my card, I don’t want a 1000-in-1 gauges card.
What I do see as an option is for that value_texts to be icons. Maybe that’s something worth investigating.
Edit:
My current Work-In-Progress already adds some extra content to the card. I feel it’s quite packed now and shouldn’t >add< too much information more to it. That’s why I’m thinking about using the value_text (the 19°C and maybe the 55%) field for icons, not adding them somewhere else. Unless you/somehow finds a way to convince me :smiley:
I agree with you on this - keep it simple, and what’s available have a lot of options.
Just a side question: is it an error on your github page: you have written:
  • value_texts → value_text ?
  • titles → title ? (when does this title appears at all? I can’t make it show…)
That’s some changed/new config for v0.8.0 which I hope to release somewhere soon. I’m merging some attributes into groups for better clarity of the config. I ended up with something like:
primary
primary_color
secondary
secondary_color
value_text
value_text_color
inner:
  • value_text
  • value_text_color
which will become:
titles:
  • primary
  • primary_color
  • secondary
  • secondary_color
value_texts:
  • primary
  • primary_color
  • secondary
  • secondary_color
Just downloaded and had my first play around and am very impressed! It’s available in the HACS store now BTW - no need to copy the custom URL :sunglasses:
I’m trying to understand the colours:
In your examples you use colour names, eg
I’ve tried replacing them with other colour names, but many don’t seem to be recognised, is there a list to choose from?
Or even better, is it possible to use an rgb colour value?
Loving your work! This is what I’ve made myself so far & love how it looks :sunglasses:
Unfortunately my card hasn’t been added yet :wink: → This is my PR. It currently takes about 6 months. I think you added my repo as custom repo to HACS. Once that’s done, you’ll receive updates as if it was a normal repo.
It’s just a personal preference to use ā€˜HA’-colors. RGB should definitely work, formatted as hex and probably quoted: "#ff0000".
Thanks a lot for your lovely feedback, goes a long way! :smiley: Love to see what people built using my card, thanks for sharing
Digging through the HA frontend source code I found this file. I think it includes the majority, if not all, color variables used by HA
I’m just wondering… is it possible to adjust/limit gradient width? Say, to make yellow and red part narrower? Right now it’s pretty wide when i set green, yellow and red severity, which is perfect for majority of uses, but perhaos it could be the case when narrower gradient would be nice (just a thought)
Currently no option is available to adjust the width.
I am wondering if you are looking to reduce the width of the entire main-gauge and/or inner-gauge or just a part of one ?
I’d just limit transition width from green to yellow, for example (and from yellow to red…). Now it’s pretty wide, even if i set limits near max. green starts to transition to yellow at appr. middle of the gauge.
I might understand what you are talking about. You are specifically talking about the severity option right? With the green, yellow andred parameters right?
In v0.8.0 I dropped support for severity in favour of generic segments use. If everything works as I expect, once you update to the current release your severity-config will be converted to segments in your editor.
segments also give you the power to control the way the gradient is created. For example, let’s say you had the following severity-config:
severity:
  green: 0
  yellow: 50
  red: 100
This is converted to the following segments-config
segments:
    color: green
    color: yellow
    color: red
which looks like:
Now, looking at your question, with segments you can control the ā€œdistanceā€ where to gradient is applied, for example:
segments:
    color: green
    color: green
    color: yellow
    color: red
    color: red
which looks like:
Ok, repeating same commands does the job i want…
what i mean is to change this:
to this:
I managed to achieve this by doubling same color commands, as you suggested above:
old way:
segments:
    color: green
    color: yellow
    color: red
new way:
segments:
    color: green
    color: green
    color: yellow
    color: red
(however, i see that this ā€œshortcutā€ lowers gradient resolution…)
That is indeed correct. My current issue is that in your green part, the gradient-engine of my card still creates green parts (it’s not 1 element, although it’s all the same colour). I could increase the resolution for high or add and extra ultra option. This however impacts performance I think. Will give it a thought …
Well, i don’t mind resolution… anything is better than built-in gauge card without it.
As i said in my first post, it was more or less just a thought. After all i use it for monitoring my HA and proxmox (ram, data, space, temperature…), and it’s way more beautiful as built-in gauge card.
Thanks!
