I would love to see an option to change the values font size, sometimes a value is huge on text⦠same idea as the titles sizes for values and such would be great. Love this card, use it a lot!
Great you love it! For now, I deliberately didnāt implement the font-size config for the value_texts as they automatically scale depending on the content. This makes we wonder why you would want to change it. The texts shouldnāt outgrow into the gauges (although Iāve noticed the secondary text to be to wide, so this will be fixed in an upcoming release).
Do you feel the texts can be too large compared to other cards in your dashboard perhaps? Would love to find out!
Yep, i noticed that, too. Iām glad youāll fix itā¦
Regarding font size: as long as thereās discussionā¦i agree that if information is very short (like 15W, 35%ā¦) number shown can be pretty big and ādoesnāt quite fitā into dashboardās aesthetics, if other fonts are way smaller. Perhaps alt+0160 (non-breaking space) on the left and on the right would help in this caseā¦
But, to prevent user to set too big fontā¦one of options is to implement percentage - say default is 100%, but user could make it smaller, but not bigger (over 100%)ā¦
But iām talking out of my head, not from a programmers viewā¦sorryā¦![]()
Iām actually trying to make my card easy to use from a user perspective, not a programmer perspective ![]()
Iāve just release v1.1.0 which includes an experimental feature to reduce the font-size. Let me know what you think of it!
(wow, that was fastā¦)
Excellent! Works like a charm. Whatās good about this is if you have more of these gauges (like me) itās possible to āunifyā them so all of them have same font size and it looks nicer that way.
Iāll be āa bit naughtyā now⦠but is it possible to do the same with value_text ? Now that i unified my titles values stand out with different sizesā¦
titles already have a (templatable) font-size attribute.
Not titles, but āvalue_textā part⦠i wrote a bit confusing - wrongly (sorry)
with this:
i meant: by unifying ātitleā font size now my āvalue_textā part stands out with different fonts (left temp is now bigger than right RAM value):
Sorry for perhaps not understanding, but thatās the whole point of the attribute introduced in v1.1.0 right
Something else: are you aware of the on_main mode for the inner gauge? Of course itās all personal preference
Ahh⦠now iām feeling stupidā¦
I totally mixed up things and overlooked primary_font_size_reduction ⦠i donāt know why i constantly thought on titles⦠but they already do have font size setting⦠iām extremely sorry! Yep, with this new setting on all gauges things are looking nice and even!
No, i didnāt come to that yet⦠but itās a great function, way nicer than (unnecesarry in my case) dual color gauge. Thanks!
well some sensor names are long and the output same, then it fits, but the values " touch " the gauges ⦠so if font size of value text could be edited, great, as this works perfect for titles. thanks!
here is an example. you see 7071 / 10240 GB in blue, with a little small font it looks smoother
And then I would not mind the 69,1% is smaller. Yes, I could calculate the 10240GB to 10TB ![]()
Is this with v1.0.0 or v1.1.0?
Just got 1.1.0 installed, so the card should be updated. I updated the card and changed some to save space in text.
okay update, edit some and uses the value as title as this give me more options to size and model the layout.
happy now ![]()
Just sharing how Iāve been using the add on and also wanted to say thank you.
I made some automations to stop my devices from charging based on the wattage. Iām able to use the inner guage to show a variable threshold. Iād actually like to use the setpoint needle, but it doesnāt yet support an entity, does it?
Anyway, thanks for making things look great!
Very cool to see it used, thanks for sharing!
The value property of setpoint allows templates. So you can definitely use something like "{{ states('sensor.threshold') }}"
When I asked my AI, it said āyou canātā. They are so authoritative when they answer questions! Thanks for that.
Forget AIā¦itās written by humans, so it can never be as clever as we areā¦![]()
I was able to dynamically update min and max from sensor data, but need to also set segment thresholds dynamically calculated from sensor capacity. My container capacites change (passed in data), so I would like the gradient to be accurate. Any chance of making them JS templateable? I am using config-template-card. Not sure if I am missing something. New to HA.
Comparison of two water temperature sensors in my aquarium.
Original Cards
Original Gauge Card Code
- type: conditional
conditions:
- condition: screen
media_query: '(min-height: 800px)'
card:
type: custom:layout-card
layout_type: custom:grid-layout
cards:
- type: gauge
entity: sensor.seney_temperature
needle: true
min: 27
max: 29.5
severity:
green: 27.9
yellow: 28.5
red: 29
Gauge Card Pro
Gauge Card Pro Code
- type: grid
square: false
cards:
- type: custom:gauge-card-pro
entity: sensor.fish_tank_water_temp
min: 27
max: 29.5
segments:
color: '#3196e2'
color: '#43a047'
color: '#ffa600'
color: '#db4437'
needle: true
gradient: false
titles:
primary: '{{ state_attr(entity, ''friendly_name'') }}'
entity2: sensor.seney_temperature
inner:
min: 27
max: 29.5
segments:
color: '#3196e2'
color: '#43a047'
color: '#ffa600'
color: '#db4437'
mode: needle
gradient: false
Gradient Colours not lining up with Solid Colours
When changing this to a gradient with the same segments, what should be a green colour is shown as a yellow.
The gradient seems like it is calculated on the mid point between the two values you want.
Value Adjustment
Value adjustment to make Solid Colours match Gradient Colours using the mid point value for Gradient Colours
Adjusted Code to make Gradient Colours match Solid Colours**
- type: grid
square: false
cards:
min: 27
max: 29.5
segments:
color: '#3196e2'
color: '#43a047'
color: '#ffa600'
color: '#db4437'
needle: true
gradient: true
titles:
inner:
min: 27
max: 29.5
segments:
color: '#3196e2'
color: '#43a047'
color: '#ffa600'
color: '#db4437'
mode: needle
gradient: false
min, max and segments for both main and inner-gauge are already jinja-templatable. Is there any reason you specifically need JS?
