Can’t find anyone else reporting this (or I missed it).
My case:
I’m measuring the Humidity in my living room using an ESPHome made AQS. Works great but I also want to make things visible as they should be.
For Humidy inside the house the ideal Humitity level is between 40% and 60% Below and higher is unhealthy. So this way I want to use the Gauge card to show values as follows:
Between 0% and 39% in RED
Between 40% and 60% in Green
Between 60% and 100% in RED
Currently there’s only a severity possibility which has green, yellow, and red.
Humidy seems to be very common to measure if you ask me so this can be of great value of many HA Enhusiasts
This can be usefull to everything that needs a value between 2 values.
