Gauge card tap action "solution" sharing
I’m sharing my “solution” to add tap action to gauge card, it’s not the cleanest solution, but it works.
type: custom:button-card
custom_fields:
  gauge:
    card:
      type: gauge
      entity: sensor.total_power
      needle: true
      min: -6000
      max: 8000
      severity:
        green: 0
        yellow: 6600
        red: 7500
      card_mod:
        style: |
          ha-card {
            box-shadow: none;
            border: none;
styles:
  custom_fields:
    gauge:
      - overflow: unset
      - z-index: -1
  card:
    - overflow: unset
    - filter: opacity(100%)
    - padding: 0px
  grid:
    - grid-template-areas: '"gauge"'
    - grid-template-columns: 100%
    - grid-template-rows: 100%
tap_action:
  action: navigate
  navigation_path: /dashboard-default/energy
Thanks very much for this! It’s been driving me mad trying work out a solution, then I found your post. Hero.
@Pico81 Hi again, I had this working perfectly thanks to your code but I’ve found out that when the page is refreshed I get ‘Custom element doesn’t exist: gauge’
Any ideas what could be wrong? Thanks
Hi, have you solved it? I think it’s due to the custom-button-card JS being loaded into the browser cache
Thanks for sharing your solution!
While looking around I stumbled on a different approach on Reddit. It’s also using a button card. But it feels more clean: https://www.reddit.com/r/homeassistant/s/aG7UkMBnTQ
This solution uses the custom:layout-card to put a transparant button on top of one or more other cards (I.e gauges).
Tap action will be natively supported for gauge card coming in 2024.6
Thanks, nice work
Thanks, that is good news :tada:
Thanks!!! It works great
