Gauge Card
After seeing the sweet system monitoring post I’ve been trying to beef mine up using netdata to pull system resources from other machines in.
I’ve got this all working, however the neatdata sensors use GB for measurement instead of TB, there for the text on my gauge card is pretty big. Is there anyway to shrink the text or is it possible to add a template sensor to change the GB measurement to TB?
Also if anyone has a working sensor template to take the system uptime from seconds to days, hours etc that would be brilliant. Code form existing topics on this subject doesn’t seem to work for me.
Sure:
  sensors:
    disk_b_tb:
      friendly_name: Disk B
      entity_id: sensor.your_disk_b_gb_sensor
      value_template: "{{ (states('sensor.your_gb_sensor') | float / 1000 ) | round(2) }}"
      unit_of_measurement: "TB"
The other option is to change the font with card-modder
Brilliant this worked a treat, thank you.
