I have a weird issue. I have some gauge cards that show things like temperature and humidity and such. For some reason, the text of the values has changed to black instead of white. The cards have a dark gray background, so it’s hard to read. I can’t figure out how it got changed to black or how to change it back to white. Any suggestions?
You seem to be not using a default theme.
I never installed any themes, so it should be whatever system default is. It’s been fine for a long time. This is a new issue. I suspect an update changed something. If you have any suggestions on how to correct the problem, please explain.
After searching for awhile due to Ildar_Gabdullin’s reply, I finally found the setting to choose dark mode. That fixed the text color.
