Gauge wont work with template
This works fine but has hard coded values that are wrong half the time.
type: gauge
entity: sensor.difference_between_temperatures
max: 1
needle: true
severity:
  green: 0
  yellow: 0.5
  red: 0.75
min: 0
What I want to do is something like this. No hard coded values but derived values instead.
type: gauge
max:  {{ states('sensor.difference_between_temperatures_okay') * 2.0  }}
needle: true
severity:
  green: 0
  yellow: {{ states('sensor.difference_between_temperatures_okay')  }}
  red: {{ (states('sensor.difference_between_temperatures_okay') * 1.5)  }}
min: 0
Is something like the above possible? I can’t use hard coded values since they change based on the hour of the day.
Quite a lot of cards donot allow this, use this
iantrich/config-template-card: :memo: Templatable Lovelace Configurations (github.com)
I would not suggest using config-template-card with the Gauge.
Go to auto-entities main thread - search for “gauge” - find my solution for templating the Gauge
Care to be a bit less cryptic so people can understand (myself included) :slight_smile:
IMO there is nothing wrong with using template cards
Using particularly config-template-card will cause a total redraw of an inner card on every change of “monitored” entity.
In case of particularly Gauge card - that redraw will cause undesired animation for a needle.
There are plenty of threads here about this undesired effect.
I assume you mean this? Max and min dynamic value in Gauge card? - #7 by Ildar_Gabdullin
Yes, this one
