Hey Folks,
Just trying to gauge some interest… I hope this is ok on here??
I’ve been engineering an IP based encoder (Ethernet) which is USB based using some new cost-effective RISC-V silicon.
The solution provides a plug-and-play full framerate highish-res - up-to 4x 1080p60 or 6x 1280x800p60 - virtual displays per USB device with each being outputted via IP/Ethernet.
It would support both Windows and Linux on relatively low-end hardware (e.g 5th Gen Intel onwards) with no discrete GPU requirements (iGPU is fine).
Optimised for ultra low latency as well as multi-touch input.
A POE + USB-C powered Ethernet and WiFi6 Dual Band thin-client with 10.1" multi-touch display has been proven too.
Smaller screen sizes are possible, for example, square 4" display with native resolution.
With a bit of app engineering it’s possible to run multiple Chromium instances on each of the virtual displays headlessly & reliably.
Goal is for it to be truly plug-and-play, simply install the app and driver, plug the USB device in and connect to network.
Connect client(s) to network and you have multiple fully featured Home Assistant dashboards (any WebUI) which are also able to view cameras in as many rooms as you like.
Cost wise - actively trying to engineer a solution to be highly competitive.
Would you be interested in something like this - no headaches, no complexity, always available, fully embedded bare-metal firmware which provides industrial grade levels of reliability?
There will be other features too such as local push alerts, RGB, Neural Voice and Voice Assistant.
Any and all feedback is welcome ![]()
Thanks in advanced
