jpcolin
(JP)
October 4, 2018, 9:54am
1
I’m new here, i’m still evaluating if i will go for HASS of Openhab, one thing that still makes a no go for me is a IPX800 integration.
All my home automation is on Myhome SCS form Legrand/Bicino, but my pool automation runs on the IPX800.
Since i would like to integrate everything in a HA “HUB/Software” this is quite important for me.
Everything else i need/have has an existing module (Sonos, Hue, SCs myhome, Pioneer AVR, Panasonic TV, Doorbirde, Waze, Daikin, Synology SS, Kodi, …) wich is impressing!
Are there plan to make a component for the IPX800?
Thank you
Benoit7
(Benoit Sibold)
November 21, 2018, 9:57pm
2
+1 I’m also very interested to have IPX800 integration into HA
thanks
Do you have find a solution for you Ipx800?
Ayoubmx
(Ayoub HAJJAM)
June 17, 2019, 11:48am
4
Hi all,
I’m also very interested to have IPX800 integration into HA or Siemens PLCs Integration. S7-1200, S7-1500 and logo.
thanks
I’m a domoticz user and I’m trying Home Assistant but unfortunately I don’t know how to interface my IPX800v4 which manage all lights in my house. I have understood that it’s not possible because it’s not integrated. Is it true?
Even if there is no plug and play solution, how could I interface it ? By a script ?
pat1300
December 18, 2019, 9:17pm
6
Very interested by IPX800 integration.
Thanks,
Patrick - Belgium
tt-hass
(Thierry Lenoir)
February 3, 2020, 9:42am
7
Dears,
I made the integration IPX800-V3 & HA
In a nutshell
1 - Create switch REST to send cmd in HTTP
2 - Send notif from IPX to HA to update switch status
3 - Retreive swithc status from IPX via status.xml to update HA switches at starting time
So need to find time to explain it in details + sharing code
ThL
Canaletto
(Lionel)
February 9, 2020, 2:39pm
8
Yes @tt-hass , please share the details and code…
Thanks, lionel
Very good news! I am alos waiting for integration of IPX800
Thanks,
Patrick ( Belgium)
Canaletto
(Lionel)
February 23, 2020, 10:34pm
10
He my solution for the ipx800 v2
ipx800_7_vmc:
command_on: 'curl "http://192.168.210.31/preset.htm?led7=1" >/dev/null'
command_off: 'curl "http://192.168.210.31/preset.htm?led7=0" >/dev/null'
command_state: 'curl "http://192.168.210.31/status.xml"'
value_template: '{% set status = value | regex_findall_index("<led6>(.*)</led6>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: VMC
More infos in french for HA…
Suite à cet article les choses ont bien avancées. Mon premier soucis étant le chauffage, l'objectif étant de faire au moins aussi bien avec HA qu'avec Jeedom. La philosophie des deux produit est bien différente, sur Jeedom on confie les taches à des...
Comme je l'ai déjà expliqué dans les articles précédents, Jeedom, qui a remplacé la ZiBase, me sert essentiellement à gérer mes convecteurs. Jeedom est plutôt bien fait sur ce point grâce aux plugin Thermostat, Mode et Agenda. On va voir ici que l'on...
I’m new here.
Can you tell me exactly how to add it to your home assistant?
What should I set in configuration.yaml and what component should I install?
I have:
IPX800 pro and IPX800 V3
Thank you very much.
I use this…
- platform: command_line
switches:
# IPX800 v2
ipx800_1_sejour:
command_on: 'curl "http://192.168.210.31/preset.htm?led1=1" >/dev/null'
command_off: 'curl "http://192.168.210.31/preset.htm?led1=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led0>(.*)</led0>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: 'Convecteur : Séjour'
Dear all,
Good news, this morning I have learned that somebody has developped a custom component for IPX800v4 and extension device like X-8R, X-DIMMER, X-PWM, X-24D. Below the link.
=> GCE Forum : Intégration IPX800 Home Assistant
=> Github : IPX800
Thanks, but not for the v2 and v3, and no CGE initiativ…
Hi @Laco_Jurdik ,
I did as @Canaletto explained.
Luckily I only have switches.
here is my code in the configuration.yaml file
That’s the only thing to be done.
switch:
switches:
ipx800_r1:
command_on: 'curl "http://10.0.0.201/preset.htm?led1=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led1=0" >/dev/null'
command_state: 'curl "http://10.0.0.201/status.xml"'
friendly_name: Master Bedroom
switches:
ipx800_r2:
command_on: 'curl "http://10.0.0.201/preset.htm?led2=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led2=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led1>(.*)</led1>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Dressing
switches:
ipx800_r3:
command_on: 'curl "http://10.0.0.201/preset.htm?led3=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led3=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led2>(.*)</led2>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Extra Kamer
switches:
ipx800_r4:
command_on: 'curl "http://10.0.0.201/preset.htm?led4=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led4=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led3>(.*)</led3>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Badkamer Boven
switches:
ipx800_r5:
command_on: 'curl "http://10.0.0.201/preset.htm?led5=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led5=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led4>(.*)</led4>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Slaapkamer Norah
switches:
ipx800_r6:
command_on: 'curl "http://10.0.0.201/preset.htm?led6=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led6=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led5>(.*)</led5>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Slaapkamer Maud
switches:
ipx800_r7:
command_on: 'curl "http://10.0.0.201/preset.htm?led7=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led7=0" >/dev/null'
friendly_name: Toilet Boven
switches:
ipx800_r8:
command_on: 'curl "http://10.0.0.201/preset.htm?led8=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led8=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led7>(.*)</led7>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Gang Boven
switches:
ipx800_r9:
command_on: 'curl "http://10.0.0.201/preset.htm?led9=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led9=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led8>(.*)</led8>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Zolder
switches:
ipx800_r10:
command_on: 'curl "http://10.0.0.201/preset.htm?led10=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?led10=0" >/dev/null'
value_template: '{% set status = value | regex_findall_index("<led9>(.*)</led9>") %} {% if status == "1" %} true {%- endif -%}'
friendly_name: Ventilator Afzuiging
off course 10.0.0.201 is the IP address of my IPX800 V3
Mind the difference in numbering between command_on/off and the value_template.
This is giving the following card in Lovelace UI
How to add sensors as well, can be found here:
https://forum.home-assistant.lu/t/ipx800-v3/147
hope this helps.
Good news,
The custom components for IPX800 v4 is now available on HACS.
=>https://github.com/Aohzan/ipx800
Blockquote
for those who might be interested, here’s the configuration with the new command_line:
entry in configuration.yaml:
# Entry for GCE IPX800 V3
command_line: !include configurations/GCE_IPX800_V3.yaml
the content of the configurations/GCE_IPX800_V3.yaml file
# ipx800_r1
- switch:
name: Licht Master Bedroom
unique_id: "Licht_Master_Bedroom"
# ipx800_r2
- switch:
unique_id: "Licht_Dressing"
# ipx800_r3
- switch:
name: Licht Chillkamer
unique_id: "Licht_Chillkamer"
# ipx800_r4
- switch:
name: Licht Badkamer boven
unique_id: "Licht_Badkamer_boven"
# ipx800_r5
- switch:
name: Licht Slaapkamer Norah
unique_id: "Licht_Slaapkamer_Norah"
# ipx800_r6
- switch:
name: Licht Slaapkamer Maud
unique_id: "Licht_Slaapkamer_Maud"
# # ipx800_r7
- switch:
name: Licht Toilet boven
unique_id: "Licht_Toilet_Boven"
# ipx800_r8
- switch:
name: Licht Gang boven
#there's a bug in the firmware which does not allow the preset.htm?ledx=0 to be used for leds bigger than 8. preset.htm?setx=0 is to be used
unique_id: "Licht_Gang_boven"
# ipx800_r9
- switch:
command_on: 'curl "http://10.0.0.201/preset.htm?set9=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?set9=0" >/dev/null'
unique_id: "Licht_Zolder"
# ipx800_r10
- switch:
command_on: 'curl "http://10.0.0.201/preset.htm?set10=1" >/dev/null'
command_off: 'curl "http://10.0.0.201/preset.htm?set10=0" >/dev/null'
unique_id: "Ventilator Afzuiging"
