Having problems with the GDACS integration. It’s 404ing on an rss feed. Only thing I can find on the webpage is a download of an xml file.
This is the URL the integration fetches: https://www.gdacs.org/xml/rss.xml
The service is temporarily unavailable from time to time. A 404 indicates that the server on their end responded but did not serve the file, otherwise you can expect occasional timeouts if you HA instance can’t reach their server.
And, once the integration is set up, you also get a status sensor sensor.gdacs_home
that gives you some more details about how many events are tracked, when the last success updates was, etc.
Thanks, I see the rss is working now.
