I just purchased the GE 12721 switch for my espresso maker, I’m using a RB pi3 with HA AIO and a Aeotec ZW090 Z-Stick Gen5 for zwave devices. At first the switch works as intended when I manually turn it on but as time goes it glitches out and it won’t take the command to turn on or off, also if I manually turn it on it won’t update the status. Below is my config, any ideas how I can fix this?
Zwave
zwave:
usb_path: /dev/ttyACM0
config_path: /srv/homeassistant/src/open-zwave-control-panel/config
This is what happens when click “ON/OFF”
2016-12-29 21:20:02.876 Always, OpenZwave Version 1.4.2296 Starting Up
2016-12-29 21:20:03.563 Info, Setting Up Provided Network Key for Secure Communications
2016-12-29 21:20:03.563 Warning, Failed - Network Key Not Set
2016-12-29 21:20:03.563 Info, mgr, Added driver for controller /dev/ttyACM0
2016-12-29 21:20:03.563 Info, Opening controller /dev/ttyACM0
2016-12-29 21:20:03.564 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2016-12-29 21:20:03.566 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2016-12-29 21:20:03.569 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-29 21:20:03.569 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-12-29 21:20:03.570 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-12-29 21:20:03.570 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-12-29 21:20:03.570 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-12-29 21:20:03.570 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2016-12-29 21:20:04.538 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x35, 0x00, 0x01, 0x99
2016-12-29 21:20:04.539 Detail,
2016-12-29 21:20:04.539 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2016-12-29 21:20:04.539 Info, contrlr, Static Controller library, version Z-Wave 3.95
2016-12-29 21:20:04.539 Detail, Node045, Expected reply was received
2016-12-29 21:20:04.539 Detail, Node045, Message transaction complete
2016-12-29 21:20:04.539 Detail, contrlr, Removing current message
2016-12-29 21:20:04.540 Detail,
2016-12-29 21:20:04.540 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2016-12-29 21:20:04.543 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xdd, 0xf7, 0xc7, 0xb1, 0x01, 0x8b
2016-12-29 21:20:04.543 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xddf7c7b1. Our node ID = 1
2016-12-29 21:20:04.543 Detail, Node247, Expected reply was received
2016-12-29 21:20:04.543 Detail, Node247, Message transaction complete
2016-12-29 21:20:04.543 Detail, contrlr, Removing current message
2016-12-29 21:20:04.544 Detail,
2016-12-29 21:20:04.544 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2016-12-29 21:20:04.546 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2016-12-29 21:20:04.546 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2016-12-29 21:20:04.546 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2016-12-29 21:20:04.546 Info, contrlr, The PC controller is a primary controller.
2016-12-29 21:20:04.546 Detail, Node247, Expected reply was received
2016-12-29 21:20:04.546 Detail, Node247, Message transaction complete
2016-12-29 21:20:04.546 Detail, contrlr, Removing current message
2016-12-29 21:20:04.546 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2016-12-29 21:20:04.550 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x00, 0x00, 0x86, 0x01, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2016-12-29 21:20:04.550 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2016-12-29 21:20:04.550 Info, contrlr, Serial API Version: 1.0
2016-12-29 21:20:04.550 Info, contrlr, Manufacturer ID: 0x0086
2016-12-29 21:20:04.551 Info, contrlr, Product Type: 0x0101
2016-12-29 21:20:04.551 Info, contrlr, Product ID: 0x005a
2016-12-29 21:20:04.551 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-12-29 21:20:04.551 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-12-29 21:20:04.551 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-12-29 21:20:04.551 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-12-29 21:20:04.551 Detail, Expected reply was received
2016-12-29 21:20:04.551 Detail, Message transaction complete
2016-12-29 21:20:04.551 Detail, contrlr, Removing current message
2016-12-29 21:20:04.551 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2016-12-29 21:20:04.553 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2016-12-29 21:20:04.553 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2016-12-29 21:20:04.553 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2016-12-29 21:20:04.553 Detail, Node172, Expected reply was received
2016-12-29 21:20:04.553 Detail, Node172, Message transaction complete
2016-12-29 21:20:04.553 Detail, contrlr, Removing current message
2016-12-29 21:20:04.553 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2016-12-29 21:20:04.609 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x0c, 0x4b, 0x4f, 0x58, 0x5e, 0xad, 0x4b, 0xb6, 0xd3, 0x7f, 0x82, 0x4f, 0x82, 0x91, 0x98, 0x85, 0xee, 0x01, 0x96, 0x1f, 0x7a, 0xd2, 0x1c, 0x7d, 0xa4, 0xb0, 0x47, 0xb1, 0xc3, 0x60, 0x59, 0x5f, 0x3f
2016-12-29 21:20:04.609 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2016-12-29 21:20:04.609 Detail, Node032, Expected reply was received
2016-12-29 21:20:04.609 Detail, Node032, Message transaction complete
2016-12-29 21:20:04.609 Detail, contrlr, Removing current message
2016-12-29 21:20:04.609 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2016-12-29 21:20:04.711 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc7
2016-12-29 21:20:04.711 Info, mgr, Driver with Home ID of 0xddf7c7b1 is now ready.
2016-12-29 21:20:04.717 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2016-12-29 21:20:04.718 Info, contrlr, Node 001 - Known
2016-12-29 21:20:04.718 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-12-29 21:20:04.718 Detail, Node001, QueryStage_CacheLoad
2016-12-29 21:20:04.718 Info, Node001, Node Identity Codes: 0086:0101:005a
2016-12-29 21:20:04.718 Detail, Node001, QueryStage_Associations
2016-12-29 21:20:04.718 Detail, Node001, QueryStage_Neighbors
2016-12-29 21:20:04.718 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2016-12-29 21:20:04.718 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-12-29 21:20:04.718 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2016-12-29 21:20:04.718 Info, contrlr, Node 002 - Known
2016-12-29 21:20:04.718 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2016-12-29 21:20:04.718 Detail, Node002, QueryStage_CacheLoad
2016-12-29 21:20:04.718 Info, Node002, Node Identity Codes: 0063:4952:3031
2016-12-29 21:20:04.718 Info, Node002, NoOperation::Set - Routing=true
2016-12-29 21:20:04.718 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2016-12-29 21:20:04.718 Detail, Node002, Queuing (Query) Query Stage Complete (CacheLoad)
2016-12-29 21:20:04.718 Detail, Expected reply was received
2016-12-29 21:20:04.718 Detail, Message transaction complete
2016-12-29 21:20:04.719 Detail,
2016-12-29 21:20:04.719 Detail, contrlr, Removing current message
2016-12-29 21:20:04.719 Detail, Node001, Notification: DriverReady
2016-12-29 21:20:04.727 Detail, Node001, Notification: NodeAdded
2016-12-29 21:20:04.728 Detail, Node001, Notification: NodeProtocolInfo
2016-12-29 21:20:04.739 Detail, Node001, Notification: EssentialNodeQueriesComplete
2016-12-29 21:20:04.740 Detail, Node001, Notification: ValueAdded
2016-12-29 21:20:04.741 Detail, Node001, Notification: NodeNaming
2016-12-29 21:20:04.742 Detail, Node002, Notification: NodeAdded
2016-12-29 21:20:04.743 Detail, Node002, Notification: NodeProtocolInfo
2016-12-29 21:20:04.744 Detail, Node002, Notification: EssentialNodeQueriesComplete
2016-12-29 21:20:04.746 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.749 Info, Node002, DisablePoll failed - value not on list
2016-12-29 21:20:04.749 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.754 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.758 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.760 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.763 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.765 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.772 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.779 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.786 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.792 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.799 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.822 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.823 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.828 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.836 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.837 Detail, Node002, Notification: ValueAdded
2016-12-29 21:20:04.838 Detail, Node002, Notification: NodeNaming
2016-12-29 21:20:04.838 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2016-12-29 21:20:04.842 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2016-12-29 21:20:04.843 Detail,
2016-12-29 21:20:04.843 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2016-12-29 21:20:04.843 Detail, Node015, Expected reply was received
2016-12-29 21:20:04.843 Detail, Node015, Message transaction complete
2016-12-29 21:20:04.843 Detail, contrlr, Removing current message
2016-12-29 21:20:04.843 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2016-12-29 21:20:04.845 Detail, contrlr, Removing current message
2016-12-29 21:20:04.846 Detail,
2016-12-29 21:20:04.846 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2016-12-29 21:20:04.851 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5c
2016-12-29 21:20:04.851 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2016-12-29 21:20:04.851 Info, Node001, Neighbors of this node are:
2016-12-29 21:20:04.851 Info, Node001, Node 2
2016-12-29 21:20:04.851 Detail, Expected reply was received
2016-12-29 21:20:04.851 Detail, Message transaction complete
2016-12-29 21:20:04.851 Detail, Node001, Removing current message
2016-12-29 21:20:04.852 Detail,
2016-12-29 21:20:04.854 Info, Node002, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2016-12-29 21:20:04.865 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-29 21:20:04.865 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-29 21:20:06.295 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2016-12-29 21:20:06.295 Info, Node002, SwitchBinary::Set - Setting node 2 to On
2016-12-29 21:20:06.295 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Set (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x25, 0x01, 0xff, 0x25, 0x0b, 0x12
2016-12-29 21:20:06.296 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x0c, 0xeb
2016-12-29 21:20:08.983 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x01, 0x01, 0x9c, 0x7d
2016-12-29 21:20:08.983 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2016-12-29 21:20:08.983 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-29 21:20:08.983 Warning, Node002, WARNING: Device is not a sleeping node.
2016-12-29 21:20:08.983 Info, Node002, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 0 pending 1
2016-12-29 21:20:08.983 Detail, Node001, Expected callbackId was received
2016-12-29 21:20:08.983 Detail, Node001, Expected reply was received
2016-12-29 21:20:08.983 Detail, Node001, Message transaction complete
2016-12-29 21:20:08.984 Detail,
2016-12-29 21:20:08.984 Detail, Node002, Removing current message
2016-12-29 21:20:08.984 Detail, Node002, Notification: Notification - NoOperation
2016-12-29 21:20:08.984 Info, Node002, Sending (Send) message (Callback ID=0x0b, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x25, 0x01, 0xff, 0x25, 0x0b, 0x12
2016-12-29 21:20:08.996 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-29 21:20:08.996 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-29 21:20:13.083 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x01, 0x01, 0x99, 0x79
2016-12-29 21:20:13.083 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2016-12-29 21:20:13.083 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-29 21:20:13.084 Warning, Node002, WARNING: Device is not a sleeping node.
2016-12-29 21:20:13.084 Detail, Node001, Expected callbackId was received
2016-12-29 21:20:13.084 Detail, Node001, Expected reply was received
2016-12-29 21:20:13.084 Detail, Node001, Message transaction complete
2016-12-29 21:20:13.084 Detail, Node002, Removing current message
2016-12-29 21:20:13.084 Info, Node002, Sending (Send) message (Callback ID=0x0c, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x0c, 0xeb
2016-12-29 21:20:13.096 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-29 21:20:13.096 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-29 21:20:17.198 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0x9b, 0x7c
2016-12-29 21:20:17.198 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2016-12-29 21:20:17.198 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2016-12-29 21:20:17.198 Warning, Node002, WARNING: Device is not a sleeping node.
2016-12-29 21:20:17.198 Error, Node002, ERROR: node presumed dead
2016-12-29 21:20:17.198 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-29 21:20:17.198 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2016-12-29 21:20:17.198 Detail, Node001, Expected callbackId was received
2016-12-29 21:20:17.198 Detail, Node002, Notification: Notification - Node Dead
2016-12-29 21:20:23.085 Error, Node002, ERROR: Dropping command because node is presumed dead
2016-12-29 21:20:23.085 Detail, Node002, Removing current message
2016-12-29 21:20:23.085 Detail, Node002, Notification: Notification - TimeOut
2016-12-29 21:20:23.086 Detail, Node001, Query Stage Complete (Neighbors)
2016-12-29 21:20:23.086 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2016-12-29 21:20:23.086 Detail, Node001, QueryStage_Session
2016-12-29 21:20:23.086 Detail, Node001, QueryStage_Dynamic
2016-12-29 21:20:23.086 Detail, Node001, QueryStage_Configuration
2016-12-29 21:20:23.086 Detail, Node001, QueryStage_Complete
2016-12-29 21:20:23.086 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2016-12-29 21:20:23.086 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2016-12-29 21:20:23.086 Info, Node query processing complete except for dead nodes.
2016-12-29 21:20:23.087 Detail, Node001, Notification: NodeQueriesComplete
2016-12-29 21:20:23.087 Detail, contrlr, Notification: AllNodesQueriedSomeDead
2016-12-29 21:20:23.088 Detail, Node002, Query Stage Complete (CacheLoad)
2016-12-29 21:20:23.088 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=1 queryStage=CacheLoad live=0
