GE 14294 (and Jasco equivilant) ZWave dimmer double tap (Event on Associaton Group 3) - need config help
Great info! I took your findings and put together an AppDaemon app.
# SETUP
# https://community.home-assistant.io/t/ge-14294-and-jasco-equivilant-zwave-dimmer-double-tap-event-on-associaton-group-3-need-config-help/29469/17
# Forward double-tap events to your controller. In the Z-Wave configuration panel of HA:
# Select the node for the light switch you want to enable double-tap on.
# Under Node group associations select Group 3.
# Under Node to control select your Z-Wave USB stick (or whatever Z-Wave controller you use).
# Hit Add to Group
# Args:
# entities:
#   - entity: Zwave entity to monitor for double tap.
#     events:
#       - tap_up: List of actions to fire on double tap up.
#           - action_entity: Entity to perform action on. Ex: light.living_room_light
#             action: Action to perform. 'on' or 'off'
#       - tap_down: List of actions to fire on double tap down.
# NOTE: the triggering entity does not turn on by default and will need to be added as an action_entity if you would like it to.
# FULL EXAMPLE
# Double Tap Switch:
#   class: zwave_double_tap
#   module: zwave_double_tap
#   entities:
#     - entity: zwave.island_lights
#       events:
#         - tap_up:
#             - action_entity: light.living_room_light_level
#               action: 'on'
#             - action_entity: light.living_room_lamp_level
#               action: 'on'
#         - tap_down:
#               action: 'off'
# Version 1.0:
#   Initial Version
class zwave_double_tap(hass.Hass):
    def initialize(self):
        self.utils = self.get_app('utils')
        if "entities" in self.args:
            for item in self.args["entities"]:
                entity = item["entity"]
                if "events" in item:
                    self.log("Monitoring {} for double tap.".format(
                        self.friendly_name(entity)), "INFO")
                    events = item["events"]
                    self.listen_event(
                        self.zwave_event, "zwave.node_event", entity_id=entity, events=events)
    def zwave_event(self, event_name, data, kwargs):
        basic_level = data["basic_level"]
        events = kwargs["events"]
        for event in events:
            if "tap_up" in event and basic_level == 255:
                direction = "Up"
                msg = "{} event fired. ".format(direction)
                for item in event["tap_up"]:
                    action_entity = item["action_entity"]
                    action = item["action"]
                    msg += "{} will be turned {}. ".format(
                        self.friendly_name(action_entity), action)
                    domain, entity = self.split_entity(action_entity)
                    if "fan" in domain:
                        fan_speed = self.get_state(action_entity, attribute="speed")
                        new_speed = self.utils.increment_fan_speed(fan_speed)
                        self.call_service("fan/set_speed", entity_id=action_entity, speed=new_speed)
                    else:
                        service = "{}/turn_{}".format(domain, action)
                        if action == "on" and domain == "light":
                            self.call_service(
                                service, entity_id=action_entity, brightness_pct="100")
                        else:
                            self.call_service(service, entity_id=action_entity)
                self.log(msg, "INFO")
            if "tap_down" in event and basic_level == 0:
                direction = "Down"
                for item in event["tap_down"]:
                    if "fan" in domain:
                        new_speed = self.utils.decrement_fan_speed(fan_speed)
                    else:
                            self.call_service(
                        else:
In its current state this supports domains that work with the turn_on/turn_off service.
UPDATE: Support for stepping fan speed.
Requires utils.py with the following functions:
class utils(hass.Hass):
        self.log("initialized utils")
    def increment_fan_speed(self, fan_speed):
        Increment fan speed one step.
        return {
            'off': 'low',
            'low': 'medium',
            'medium': 'high'
        }.get(fan_speed, 'high')
    def decrement_fan_speed(self, fan_speed):
        Decrement fan speed one step.
        return {
            'high': 'medium',
            'medium': 'low',
            'low': 'off'
        }.get(fan_speed, 'off')
and an updated apps.yaml entry:
Double Tap Switch:
  dependencies: utils
  entities:
    ## Step Fan Speed
    - entity: zwave.living_room_fan
      events:
        - tap_up:
            - action_entity: fan.living_room_fan_level
              action: 'on'
        - tap_down:
              action: 'off'
