Is there anyway to distinguish between a double tap and a single tap after you’ve made the proper group associations?
For example, I have this automation that I only want to trigger when the light is turned on via the physical switch:
- id: powder_room_sconce_default_brightness_level
alias: Binding- Powder Room Sconce Default Brightness
initial_state: 'on'
- platform: event
event_type: zwave.node_event
event_data:
entity_id: zwave.ge_14294_inwall_smart_dimmer_33
basic_level: 255
- service: light.turn_on
data_template:
entity_id: light.powder_room_sconce
brightness_pct: >
{% if is_state("input_boolean.night_mode", "on") %} 55
{% elif is_state("input_boolean.twilight_lighting", "on") %} 65
{% else %} 80 {% endif %}
transition: 3
However, if I was to also enable double taps the basic_level would also be 255 so it appears I can only use group association for a single tap OR a double tap, not both. Am I missing something, I tried enabling debug in my logs and looking for clues as a way to distinguish from a single tap zwave event and a double tap but didn’t have any luck.
Also, I am intentionally not using the light state because I only want this to fire when the physical switch is pressed, not when controlled via automations or the HA UI.
