I’m using the HUSBZB-1 stick on a dedicated NUC. Z-wave and Zigbee works for most devices, but I’m about to start throwing cups at the wall with how frustrating it is to setup the GE 14294 dimmer.
I have added many of the options that’ve been suggested in the forums:
device_config: !include zwave_device_config.yaml
light.family_room_light:
polling_intensity: 1
refresh_value: true
delay: 3
have set the dim_rate etc.
However, the light still doesn’t really respond to any type of dimming. It turns on and off reliably. If I change the brighness of the lights while the lights are on, nothing happens. However, if I turn them back on, it actually does go to the brightness of the lights that I just set it to.
i.e.
Turn light on - brightness to 100% (works)
Brightness to 20% - (nothing happens)
Turn light off (works)
Turn light on - brightness now at 20%.
So somehow the previous brightness command did get sent, but somehow not actually changing the brightness?
