I have a GE 26931 motion sensor light switch that for the most part is working great. I have been able to switch it over to manual mode via the zwave node config.
But, for whatever reason I am unable to adjust the reset cycle parameter. It is currently set to 2 (default) and any time I try to change it to any other value (in this case 1), it simply flips back to a 2. Any ideas as to what is going on?
Below are my zwave logs:
2019-01-15 04:19:11.558 Info, Node021, Value::Set - COMMAND_CLASS_CONFIGURATION - Reset cycle - 15 - 1 - 1
2019-01-15 04:19:11.558 Info, Node021, Configuration::Set - Parameter=15, Value=1 Size=1
2019-01-15 04:19:11.558 Detail, Node021, Queuing (Send) ConfigurationCmd_Set (Node=21): 0x01, 0x0c, 0x00, 0x13, 0x15, 0x05, 0x70, 0x04, 0x0f, 0x01, 0x01, 0x25, 0xad, 0x03
2019-01-15 04:19:11.558 Detail, Node021, Queuing (Send) ConfigurationCmd_Get (Node=21): 0x01, 0x0a, 0x00, 0x13, 0x15, 0x03, 0x70, 0x05, 0x0f, 0x25, 0xae, 0x01
2019-01-15 04:19:11.559 Info, Node021, Sending (Send) message (Callback ID=0xad, Expected Reply=0x13) - ConfigurationCmd_Set (Node=21): 0x01, 0x0c, 0x00, 0x13, 0x15, 0x05, 0x70, 0x04, 0x0f, 0x01, 0x01, 0x25, 0xad, 0x03
2019-01-15 04:19:11.566 Detail, Node021, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-01-15 04:19:11.566 Detail, Node021, ZW_SEND_DATA delivered to Z-Wave stack
2019-01-15 04:19:11.607 Detail, Node021, Received: 0x01, 0x07, 0x00, 0x13, 0xad, 0x00, 0x00, 0x04, 0x42
2019-01-15 04:19:11.607 Detail, Node021, ZW_SEND_DATA Request with callback ID 0xad received (expected 0xad)
2019-01-15 04:19:11.607 Info, Node021, Request RTT 48 Average Request RTT 122
2019-01-15 04:19:11.607 Detail, Expected callbackId was received
2019-01-15 04:19:11.607 Detail, Expected reply was received
2019-01-15 04:19:11.607 Detail, Message transaction complete
2019-01-15 04:19:11.607 Detail, Node021, Removing current message
2019-01-15 04:19:11.607 Info, Node021, Sending (Send) message (Callback ID=0xae, Expected Reply=0x04) - ConfigurationCmd_Get (Node=21): 0x01, 0x0a, 0x00, 0x13, 0x15, 0x03, 0x70, 0x05, 0x0f, 0x25, 0xae, 0x01
2019-01-15 04:19:11.615 Detail, Node021, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-01-15 04:19:11.615 Detail, Node021, ZW_SEND_DATA delivered to Z-Wave stack
2019-01-15 04:19:11.679 Detail, Node021, Received: 0x01, 0x07, 0x00, 0x13, 0xae, 0x00, 0x00, 0x07, 0x42
2019-01-15 04:19:11.679 Detail, Node021, ZW_SEND_DATA Request with callback ID 0xae received (expected 0xae)
2019-01-15 04:19:11.679 Info, Node021, Request RTT 72 Average Request RTT 97
2019-01-15 04:19:11.679 Detail, Expected callbackId was received
2019-01-15 04:19:11.753 Detail, Node021, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x15, 0x06, 0x70, 0x06, 0x0f, 0x02, 0x00, 0x02, 0x9d
2019-01-15 04:19:11.753 Info, Node021, Response RTT 145 Average Response RTT 429
2019-01-15 04:19:11.753 Detail, Node021, Refreshed Value: old value=2, new value=2, type=byte
2019-01-15 04:19:11.753 Detail, Node021, Changes to this value are not verified
2019-01-15 04:19:11.753 Info, Node021, Received Configuration report: Parameter=15, Value=2
2019-01-15 04:19:11.753 Detail, Node021, Expected reply and command class was received
2019-01-15 04:19:11.753 Detail, Node021, Message transaction complete
