I am trying to buy the GE - Z-Wave In-Wall Smart Add-On Toggle Switch but I was wondering whether it will work with HUSBZB-1 Zigbee/Zwave hub.
Has anyone tried it?
The Add-On switch must be used with a “regular” GE smart switch, such as the model 12727 or 14292, to form a “3-Way”, “4-Way”, etc. switch configuration. The “regular” switch is the one that interacts with HA via Z-Wave. I use all of these models (and more) from GE, and they all work just fine with HA. I use an Aeotec Z-Wave USB stick, so I can’t speak specifically about the HUSBZB-1.
I have the controller and the add on switches work just fine when paired with a “real” ge switch or dimmer as Stated above. I have one as a 3 way and one 4way
Thank you for confirming.
