I am using Node Red to slowly turn up a light bulb to wake me up. The flow will periodically issue light.turn_on with brightness_pct to the Home Assistant API. Mostly it works correctly, and the light slowly gets brighter. However, in a few cases, it will go dimmer, then brighter when the light.turn_on command is issued. I debugged Node Red and confirmed that the flow was NOT sending these commands. I tailed OZQ_Log.txt and I noticed the following (it is trying to set the brightness_pct to 81):
2019-12-19 15:47:52.817 Info, Node007, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 81
2019-12-19 15:47:52.817 Info, Node007, SwitchMultilevel::Set - Setting to level 81
2019-12-19 15:47:52.817 Detail, Node007, Queuing (Send) SwitchMultilevelCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x26, 0x01, 0x51, 0x25, 0xaa, 0x1b
2019-12-19 15:47:52.817 Detail, Node007, Queuing (Send) SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xab, 0x4a
2019-12-19 15:47:52.817 Info, Node007, Sending (Send) message (Callback ID=0xaa, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x26, 0x01, 0x51, 0x25, 0xaa, 0x1b
2019-12-19 15:47:52.824 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-19 15:47:52.824 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2019-12-19 15:47:52.845 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0xaa, 0x00, 0x00, 0x03, 0x42
2019-12-19 15:47:52.845 Detail, Node007, ZW_SEND_DATA Request with callback ID 0xaa received (expected 0xaa)
2019-12-19 15:47:52.845 Info, Node007, Request RTT 28 Average Request RTT 36
2019-12-19 15:47:52.845 Detail, Expected callbackId was received
2019-12-19 15:47:52.845 Detail, Expected reply was received
2019-12-19 15:47:52.845 Detail, Message transaction complete
2019-12-19 15:47:52.845 Detail, Node007, Removing current message
2019-12-19 15:47:52.845 Info, Node007, Sending (Send) message (Callback ID=0xab, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xab, 0x4a
2019-12-19 15:47:52.853 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-19 15:47:52.853 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2019-12-19 15:47:52.898 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0xab, 0x00, 0x00, 0x05, 0x45
2019-12-19 15:47:52.898 Detail, Node007, ZW_SEND_DATA Request with callback ID 0xab received (expected 0xab)
2019-12-19 15:47:52.898 Info, Node007, Request RTT 52 Average Request RTT 44
2019-12-19 15:47:52.898 Detail, Expected callbackId was received
2019-12-19 15:47:52.939 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x26, 0x03, 0x51, 0x82
2019-12-19 15:47:52.939 Info, Node007, Response RTT 93 Average Response RTT 84
2019-12-19 15:47:52.939 Info, Node007, Received SwitchMultiLevel report: level=81
2019-12-19 15:47:52.939 Detail, Node007, Refreshed Value: old value=79, new value=81, type=byte
2019-12-19 15:47:52.940 Detail, Node007, Changes to this value are not verified
2019-12-19 15:47:52.940 Detail, Node007, Expected reply and command class was received
2019-12-19 15:47:52.940 Detail, Node007, Message transaction complete
2019-12-19 15:47:52.940 Detail, Node007, Removing current message
2019-12-19 15:47:52.940 Detail, Node007, Notification: ValueChanged
2019-12-19 15:47:52.962 Detail, Node007, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x07, 0x05, 0x26, 0x03, 0x51, 0x51, 0x00, 0xd7
2019-12-19 15:47:52.962 Info, Node007, Received SwitchMultiLevel report: level=81
2019-12-19 15:47:52.962 Detail, Node007, Refreshed Value: old value=81, new value=81, type=byte
2019-12-19 15:47:52.962 Detail, Node007, Changes to this value are not verified
2019-12-19 15:47:52.962 Detail, Node007, Notification: ValueChanged
Have you experienced similar behavior with your z-wave light switch?
I also noticed that when I tried to turn_off the light with the Home Assistant UI, the light turned off, turned back on, and then turned off again. This doesn’t always happen, but I noticed it after I finished trying to debug the node red flow.
