Hi. Newbie to HA, but not newbie to scripting, coding, etc. Just trying to figure out automations with zwave switches and lights. So here it goes. I have a GE 14294 in wall smart dimmer and it is great. It is hooked to the Z-Wave controller, and works great when I use it on the wall. When I paired it with HA, a light card appeared with the dimmer instead of the switch. It can turn the lights on and off, and can even dim them when I click the card and have the dimming option. So everything works. I just can’t figure out how to get the lights turned on in an automation. I have the option zwave.kitchen_dimmer entity to use and the light.kitchen_dimmer_level entity. Which one is best to use? Both? How do you call them from within an automation? I attached some code below and I’m just not seeing this. Thanks.
- alias: "Sunset, kitchen lights on"
platform: sun
event: sunset
offset: "-00:10:00"
- service: switch.turn_on
entity_id: zwave.kitchen_dimmer
- service: light.turn_on
entity_id: light.kitchen_dimmer_level
brightness: 3
