i have one GE/Jasco z-wave dimmer switch that was previously working fine with my HA / OZW 1.4 set up. I recently upgraded my set up and switched to the Zooz 700 S2 stick and Z-wave JS. All my older switches have been able to pair to the new stick (with a few needing a few attempts).
Unfortunately despite all my attempts, I havent been able to get this darn GE switch to pair. Prior to upgrading I excluded it from the prior set up. I have gotten it to show up as a node, but it appears as a dead node immediately after pairing. It is able to be recognized in exclusion and removes the node right away. I tried doing the reset protocol (three taps up/three taps down), with the LED signaling a successful reset. I have tried inclusion and advanced inclusion with unsecured method. It adds a node but fails to complete set up.
Here is a copy of the log file. It looks like it just fails to interview, and I cant figure out why.
Any help is greatly appreciated!
2021-11-15T02:19:47.722Z DRIVER « [REQ] [AddNodeToNetwork]
payload: 0x12053600
2021-11-15T02:19:47.723Z DRIVER handling request AddNodeToNetwork (74)
2021-11-15T02:19:47.723Z DRIVER 1 handler registered!
2021-11-15T02:19:47.723Z DRIVER invoking handler #0
2021-11-15T02:19:47.724Z CNTRLR handling add node request (status = ProtocolDone)
2021-11-15T02:19:47.724Z CNTRLR finishing inclusion process...
2021-11-15T02:19:47.729Z DRIVER » [REQ] [AddNodeToNetwork]
payload: 0xc513
2021-11-15T02:19:47.737Z DRIVER « [REQ] [AddNodeToNetwork]
payload: 0x13063600
2021-11-15T02:19:47.743Z DRIVER » [REQ] [AddNodeToNetwork]
payload: 0xc500
2021-11-15T02:19:47.749Z CNTRLR The inclusion process was stopped
2021-11-15T02:19:47.749Z CNTRLR finished adding node 54:
basic device class: Routing Slave
generic device class: Multilevel Switch
specific device class: Multilevel Power Switch
supported CCs:
· Basic (0x20)
· Multilevel Switch (0x26)
· All Switch (0x27)
· Z-Wave Plus Info (0x5e)
· CRC-16 Encapsulation (0x56)
· Version (0x86)
· Manufacturer Specific (0x72)
· Device Reset Locally (0x5a)
· Association (0x85)
· Association Group Information (0x59)
· Powerlevel (0x73)
· Configuration (0x70)
· Scene Actuator Configuration (0x2c)
· Scene Activation (0x2b)
· Firmware Update Meta Data (0x7a)
controlled CCs:
2021-11-15T02:19:47.751Z CNTRLR » [Node 054] Assigning SUC return route...
2021-11-15T02:19:47.756Z DRIVER » [Node 054] [REQ] [AssignSUCReturnRoute]
payload: 0x3614
2021-11-15T02:19:47.763Z DRIVER « [RES] [AssignSUCReturnRoute]
was executed: true
2021-11-15T02:19:47.844Z DRIVER « [REQ] [AssignSUCReturnRoute]
callback id: 20
transmit status: NoAck
2021-11-15T02:19:47.847Z CNTRLR [Node 054] Configuring Z-Wave+ Lifeline association...
2021-11-15T02:19:47.852Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ transmit options: 0x25
│ route: 0, 0, 0, 0
│ callback id: 21
└─[AssociationCCSet]
group id: 1
node ids: 1
2021-11-15T02:19:47.859Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:19:52.027Z DRIVER « [REQ] [SendDataBridge]
callback id: 21
2021-11-15T02:19:52.031Z CNTRLR [Node 054] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2021-11-15T02:19:52.535Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 21
group id: 1
node ids: 1
2021-11-15T02:19:52.543Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:19:56.737Z DRIVER « [REQ] [SendDataBridge]
callback id: 21
2021-11-15T02:19:56.740Z CNTRLR [Node 054] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2021-11-15T02:19:57.243Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 21
group id: 1
node ids: 1
2021-11-15T02:19:57.251Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:20:01.399Z DRIVER « [REQ] [SendDataBridge]
callback id: 21
2021-11-15T02:20:01.401Z CNTRLR [Node 054] Node 54 did not respond after 3 attempts, it is presumed dead
2021-11-15T02:20:01.403Z CNTRLR [Node 054] Failed to configure Z-Wave+ Lifeline association: Failed to send th
e command after 3 attempts (Status NoAck) (ZW0204)
2021-11-15T02:20:01.404Z CNTRLR [Node 054] Beginning interview - last completed stage: None
2021-11-15T02:20:01.404Z CNTRLR [Node 054] new node, doing a full interview...
2021-11-15T02:20:01.405Z CNTRLR » [Node 054] querying protocol info...
2021-11-15T02:20:01.410Z DRIVER » [REQ] [GetNodeProtocolInfo]
payload: 0x36
2021-11-15T02:20:01.413Z DRIVER the message was handled
2021-11-15T02:20:01.419Z DRIVER « [RES] [GetNodeProtocolInfo]
payload: 0xd39c0104110100
2021-11-15T02:20:01.422Z CNTRLR « [Node 054] received response for protocol info:
node type: Routing End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2021-11-15T02:20:01.434Z CNTRLR [Node 054] Interview stage completed: ProtocolInfo
2021-11-15T02:20:01.434Z CNTRLR » [Node 054] pinging the node...
2021-11-15T02:20:01.438Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 22
└─[NoOperationCC]
2021-11-15T02:20:01.446Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:20:05.564Z DRIVER « [REQ] [SendDataBridge]
callback id: 22
2021-11-15T02:20:05.566Z CNTRLR [Node 054] Node 54 did not respond after 1 attempts, it is presumed dead
2021-11-15T02:20:05.567Z CNTRLR [Node 054] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2021-11-15T02:20:05.568Z CNTRLR » [Node 054] querying node info...
2021-11-15T02:20:05.568Z CNTRLR » [Node 054] pinging the node...
2021-11-15T02:20:05.573Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 23
└─[NoOperationCC]
2021-11-15T02:20:05.581Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:20:09.766Z DRIVER « [REQ] [SendDataBridge]
callback id: 23
2021-11-15T02:20:09.769Z CNTRLR [Node 054] Node 54 did not respond after 1 attempts, it is presumed dead
2021-11-15T02:20:09.770Z CNTRLR [Node 054] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2021-11-15T02:20:09.771Z CNTRLR [Node 054] Interview attempt (1/5) failed, node is dead.
2021-11-15T02:21:00.392Z CNTRLR Starting inclusion process with strategy Insecure...
2021-11-15T02:21:00.396Z DRIVER » [REQ] [AddNodeToNetwork]
payload: 0xc118
2021-11-15T02:21:00.403Z DRIVER « [REQ] [AddNodeToNetwork]
payload: 0x18010000
2021-11-15T02:21:00.406Z CNTRLR The controller is now ready to add nodes
2021-11-15T02:21:02.715Z CNTRLR stopping inclusion process...
2021-11-15T02:21:02.720Z DRIVER » [REQ] [AddNodeToNetwork]
payload: 0xc519
2021-11-15T02:21:02.727Z DRIVER « [REQ] [AddNodeToNetwork]
payload: 0x19063600
2021-11-15T02:21:02.730Z CNTRLR The inclusion process was stopped
2021-11-15T02:21:14.128Z CNTRLR [Node 054] Beginning interview - last completed stage: None
2021-11-15T02:21:14.128Z CNTRLR [Node 054] new node, doing a full interview...
2021-11-15T02:21:14.129Z CNTRLR » [Node 054] querying protocol info...
2021-11-15T02:21:14.133Z DRIVER » [REQ] [GetNodeProtocolInfo]
payload: 0x36
2021-11-15T02:21:14.140Z DRIVER « [RES] [GetNodeProtocolInfo]
2021-11-15T02:21:14.142Z CNTRLR « [Node 054] received response for protocol info:
protocol version: 3
2021-11-15T02:21:14.143Z CNTRLR [Node 054] Interview stage completed: ProtocolInfo
2021-11-15T02:21:14.143Z CNTRLR » [Node 054] pinging the node...
2021-11-15T02:21:14.148Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 26
└─[NoOperationCC]
2021-11-15T02:21:14.156Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:21:18.320Z DRIVER « [REQ] [SendDataBridge]
callback id: 26
2021-11-15T02:21:18.322Z CNTRLR [Node 054] Node 54 did not respond after 1 attempts, it is presumed dead
2021-11-15T02:21:18.324Z CNTRLR [Node 054] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2021-11-15T02:21:18.324Z CNTRLR » [Node 054] querying node info...
2021-11-15T02:21:18.324Z CNTRLR » [Node 054] pinging the node...
2021-11-15T02:21:18.329Z DRIVER » [Node 054] [REQ] [SendDataBridge]
│ source node id: 1
│ route: 0, 0, 0, 0
│ callback id: 27
└─[NoOperationCC]
2021-11-15T02:21:18.337Z DRIVER « [RES] [SendDataBridge]
was sent: true
2021-11-15T02:21:22.464Z DRIVER « [REQ] [SendDataBridge]
callback id: 27
2021-11-15T02:21:22.467Z CNTRLR [Node 054] Node 54 did not respond after 1 attempts, it is presumed dead
2021-11-15T02:21:22.468Z CNTRLR [Node 054] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2021-11-15T02:21:22.469Z CNTRLR [Node 054] Interview attempt (1/5) failed, node is dead.
