I have a hallway with a single light. It can be turned on and off by either of 2 switches which happen to be at opposite ends of the hall. I bought a GE Smart Switch as well as the Add-On Switch. I wired the main switch up exactly like directed. When I got to the Add-On switch, this is where things were different from the “standard” setup. In the guide I watched, the guy had the ground, a bundle of neutral, 2 black, and a red traveler. I only had the red travel, ground, single black, and a single white. I wired up what I could and left the black undone. In the video he bundled his 2 black together and bundled the included neutral jumper with the neutral bundle. I couldn’t not get the light to work from either end. Here is how I have mine:
Main Switch:
-Line going to Line slot (voltage tested good)
-Ground to Ground
-Neutral jumper going to bundal of neutral in box
-Red Travel to Travel Slot
-Black Load to Load
At this point I initially tested the switch before touching the other switch to see if it worked, it didn’t. I know these switches are wired different than dumb switches so I figured that was the case.
Secondary Switch:
Ground to Ground
The one and only Neutral to the Neutral slot
Black Load currently not connected to anything. In the video it was bundled to another black which I don’t have.
Any advice would be appreciated since I’m not sure where to go from here. The Add-On switch doesn’t have anymore usable slots.
