GE Z-Wave In-Wall Smart Outlet 12721 not working
Hello to anyone who can help,
I have 2 12721 GE Z-Wave In-Wall Smart Outlets and neither of them are properly connecting to the Z-Wave network. They show as “unknown” in the list of devices.
My gut based on what I’ve been reading is that the .xml for the specific device is missing from here: https://github.com/OpenZWave/open-zwave/tree/master/config/ge. I see some of the other GE devices, but this one seems to not be here.
Is this something that can be added?
Thanks!
This lists the 12721 outlet, so I think you could add this file to your installation and reboot.
Awesome! Thank you for the reply @dap35.
I am running Hassio 0.58.1. What it the best or right way to include the file in my installation? Do I add it to the configuration.yaml? If so, what is the correct syntax?
Thanks!
I am not sure how to do that in hassio, since it is running in a container and you don’t have all of the access that you would in a full OS. Hopefully, someone here will have a work around, otherwise, you might open an issue on GitHub to get the update added.
