GE Z-Wave Switches double press
I have a few GE Embrighten Z-Wave swicthes and I use a GE Switch Double Tap blueprint to have the switch turn other devices on or off with a double tab. But after a recent firmware update I notice the swicth turns on or off faster than I can double press. The automations still work but there is no way to double tap the switch “on” and have the automation work without also turning the switch on.
Anyone else experiencing this?
You’ll have to say which model you have. In some cases, the firmware upgrade has disabled the double taps. [Bug Report]: Enbrighten-GE - ZW4008 - 46201 - 5.54 · Issue #82 · jascoproducts/firmware · GitHub
