Was able to make it work. Seems that actually the item I ordered was wrongly delivered. I ordered Pro and got standard. Therefore the I tried using wrong MCU. After noticing I change it and got all working.
Here my yaml for those that need it
esphome:
friendly_name: MiniMonitor2
esp8266:
board: esp01_1m
external_components:
- source:
type: git
url: https://github.com/rletendu/esphome.git
ref: st7789_nobuffer_202312
# refresh: 0s
components: [st7789v]
# Enable logging
logger:
#web_server:
# port: 80
# Enable Home Assistant API
api:
encryption:
key: "iwLC0gi1RnqBDbU5xP17esXJtnWBNMEE8e7pcP9h5qc="
ota:
password: "9228f9283cb422f5969ea917e4488bb2"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "weatherdisplaym Fallback Hotspot"
password: "NOtnhLeYNfPB"
# captive_portal:
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
interface: hardware
# status_led:
# pin: GPIO2
time:
- platform: homeassistant
output:
- platform: esp8266_pwm
pin: GPIO05
frequency: 20 Hz
light:
- platform: monochromatic
output: pwm_output
globals:
- id: page
type: int
initial_value: "1"
interval:
- interval: 15s
then:
- lambda: |-
id(page) = (id(page) + 1);
if (id(page) > 2) {
id(page) = 1;
number:
optimistic: true
min_value: 0
max_value: 3
step: 1
on_value:
then:
- lambda: |-
id(page) = x;
- component.update : disp
entity_id: sensor.gw2000c_v2_2_4_outdoor_temperature
internal: true
state_class: measurement
unit_of_measurement: °C
entity_id: sensor.gw2000c_v2_2_4_humidity
internal: true
unit_of_measurement: "%"
entity_id: sensor.gw2000c_v2_2_4_uv_index
internal: true
unit_of_measurement: UV-Index
entity_id: sensor.ac_thor_1_temperatur_1
internal: true
entity_id: sensor.total_solar_power
internal: true
unit_of_measurement: W
text_sensor:
entity_id: sensor.aktuelles_wetter
internal: true
font:
- file: "gfonts://Roboto"
image:
- file: /config/www/images/static/green.yellow.red.gradient.jpg
type: RGBA
resize: 100x16
- file: /config/www/images/static/clear-night.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/cloudy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/exceptional.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/fog.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/hail.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/lightning.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/lightning-rainy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/partlycloudy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/pouring.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/rainy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/snowy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/snowy-rainy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/sunny.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/windy.png
type: RGBA
resize: 80x80
- file: /config/www/images/static/windy-variant.png
type: RGBA
resize: 80x80
display:
- platform: st7789v
model: "Custom"
spi_id: spihwd
height: 240
width: 240
offset_height: 0
offset_width: 0
# dc_pin: GPIO02
# reset_pin: GPIO04
dc_pin: GPIO00
reset_pin: GPIO02
#backlight_pin: GPIO25
eightbitcolor: True
#update_interval: never
#update_interval: 30s
spi_mode: mode3
lambda: |-
switch (id(page)){
default:
break;
case 0:
break;
case 1:
it.printf(0, 0, id(roboto2), Color(255, 255, 255), "Wetter heute");
if (id(wcondition).has_state()) {
if (id(wcondition).state == "clear-night") {
it.image(10, 35, id(clearnight));
if (id(wcondition).state == "cloudy") {
it.image(10, 35, id(cloudy));
if (id(wcondition).state == "exceptional") {
it.image(10, 35, id(exceptional));
if (id(wcondition).state == "fog") {
it.image(10, 35, id(fog));
if (id(wcondition).state == "hail") {
it.image(10, 35, id(hail));
if (id(wcondition).state == "lightning") {
it.image(10, 35, id(lightning));
if (id(wcondition).state == "lightning-rainy") {
it.image(10, 35, id(lightningrainy));
if (id(wcondition).state == "partlycloudy") {
it.image(10, 35, id(partlycloudy));
if (id(wcondition).state == "pouring") {
it.image(10, 35, id(pouring));
if (id(wcondition).state == "rainy") {
it.image(10, 35, id(rainy));
if (id(wcondition).state == "snowy") {
it.image(10, 35, id(snowy));
if (id(wcondition).state == "snowy-rainy") {
it.image(10, 35, id(snowyrainy));
if (id(wcondition).state == "sunny") {
it.image(10, 35, id(sunny));
if (id(wcondition).state == "windy") {
it.image(10, 35, id(windy));
if (id(wcondition).state == "windy-variant") {
it.image(10, 35, id(windyvariant));
if (id(uvindex).has_state()) {
it.printf(120, 40, id(roboto3), Color(255, 255, 255), "UV Index: %.1f", id(uvindex).state);
it.image(120, 75, id(gradient));
it.rectangle(119, 74, 102, 18, Color(255, 255, 255));
int xuv = 130 + 11 * id(uvindex).state;
int luv = 90 - 11 * id(uvindex).state;
it.filled_rectangle(xuv, 75, luv, 16, Color(0, 0, 0));
// Print outside temperature (from homeassistant sensor)
if (id(outdoortemp).has_state()) {
it.printf(0, 120, id(roboto3), Color(255, 255, 255), "Temperatur");
it.printf(0, 140, id(roboto), Color(255, 255, 255), "%.1f°", id(outdoortemp).state);
// Print outside humidity (from homeassistant sensor)}
if (id(outdoorhumid).has_state()) {
it.printf(0, 180, id(roboto3), Color(255, 255, 255), "Luftfeuchtigkeit");
it.printf(0, 200, id(roboto), Color(255, 255, 255), "%.1f%%", id(outdoorhumid).state);
break;
case 2:
if (id(boilertemp).has_state()) {
it.printf(0, 0, id(roboto3), Color(255, 255, 255), "Boilertemperatur");
it.printf(0, 20, id(roboto), Color(255, 255, 255), "%.1f°", id(boilertemp).state);
// Print current pv power (from homeassistant sensor)
if (id(pvpower).has_state()) {
it.printf(0, 60, id(roboto3), Color(255, 255, 255), "Solarleistung");
it.printf(0, 80, id(roboto), Color(255, 255, 255), "%.1fW", id(pvpower).state);
break;
FYI it is possible to run it on the 8266 and also incorporate pages, but it is impossible to use OTA due to lack of free space. Also for newbies do not forget to pull GPIO0 low to enter boot mode ptherwise not programable.
If you require the weather icons sent me a message.
BR,
Chris
