Gemini Pro API
Has anyone had success in calling the new Google AI Studio (previously MakerSuite) Gemini API?
I would like to use the gemini-pro LLM model. At presently I can only seem to get the integration to use the PaLM Bison model.
Configuring the Google Generative AI Conversation Integration, I am unable to use the gemini model
models/gemini-pro
but can still use the bison model
models/chat-bison-001
The following is the error message:
Sorry, I had a problem talking to Google Generative AI: 404
models/gemini-pro is not found for API version v1beta2, or is not supported for generateMessage. Call ListModels to see the list of available models and their supported methods.
Do I need to generate a new API key?
Iā€™m the author of the Google Generative AI Conversation integration. It requires a few small changes to switch to Gemini Pro. I also plan on adding support for Gemini Pro Vision for the next core release.
Wonderful! Thank you for the fantastic integration. I look forward to the upgraded support.
Is it possible to male a wish for function calling, like it is used in extended openai conversation. So it is possible the control entities?
Google Generative AI: Add support for Gemini Pro by tronikos Ā· Pull Request #105787 Ā· home-assistant/core Ā· GitHub fixes this.
Google Generative AI: Add a service for prompts consisting of text and images using Gemini Pro Vision by tronikos Ā· Pull Request #105789 Ā· home-assistant/core Ā· GitHub adds support for Gemini Pro Vision.
@bloody2k I donā€™t have such plans
I turned it into an ā€œanything-sensorā€ yesterday, as proof of concept.
Looks like the update will be available in 2024.1! I found it in the beta release notes.
I also stumbled across this inspiration for the future of LLMs controlling Home Assistant!
So far no luck with gemini-pro in 2024.1.0. I tried removing and re-configuring the integration. Do I need a new API key? Unsure what Iā€™m doing wrong.
The PRs havenā€™t been merged yet. Hopefully they will make it in the next monthly release.
@tronikos Can we pull your repo from git via HACS to get your fixes early?
Also Iā€™m guessing @User87 wants function calling like the OpenAI conversation agent to control and send commands. That would be amazing to not have to pay for credits on OpenAI.
You can but itā€™s much easier to wait. It will be included in the 2024.2 release.
You mean 2024.2 of course :slight_smile:
One question though - Gemini Pro is not directly available in my country yet. Would it be possible to use Vertex AI API with Gemini Pro as a model instead - described here: https://ai.google.dev/examples?hl=en&keywords=vertexai
Yes I meant 2024.2. Fixed.
I donā€™t think it will work with Vertex AI API without significant changes that I donā€™t plan on making them.
Itā€™s a pity, because the direct version does not work almost anywhere in Europe and Vertex AI version would work.
Is it working now in Europe? According to Google Bard update: Image generation and Gemini Pro adds more languages itā€™s supposed to be globally available since February 1.
I have the service working perfect in dev tools/services. i cant figure out how to store the response to something i can use? Any chance you could provide an example?
Here is a script that takes a text prompt, camera to take a snapshot, and media player to play back the response:
alias: Gemini Pro Vision
fields:
  prompt:
    selector:
      text:
        multiline: true
  media_player:
    selector:
      entity:
        filter:
          - domain: media_player
  camera:
    selector:
      entity:
        filter:
          - domain: camera
sequence:
  - service: camera.snapshot
      entity_id: "{{ camera }}"
      filename: /media/snapshot.jpg
  - service: google_generative_ai_conversation.generate_content
      prompt: "{{ prompt }}"
      image_filename: /media/snapshot.jpg
    response_variable: content
  - service: tts.speak
      entity_id: tts.piper
      media_player_entity_id: {{ media_player }}
      message: "{{ content.text }}"
      cache: false
  - variables:
      content: "{{ content }}"
  - stop: end
mode: single
icon: mdi:message-image
No, it does not work, at least the API version - still getting an error for the location of the user.
yea, also I canā€™t use the nest api as an image_filename: either. I donā€™t totally understand response_variable: or blueprints either. I think what you provided is a blueprint? This is what I came up with as I believe I am also going to have to store the thumbnail in a response_variable: ?
- id: 'c12'
  alias: Doorbell Camera Snapshot Notification
    platform: device
    device_id: feb17d26775a5xxxxxxxxxxxxxxxxx
    domain: nest
    type: camera_person
    - service_template: >-
        {%- if is_state('input_boolean.home', 'off') or
               not is_state('device_tracker.iphone', 'home') and
               is_state('sensor.ipad_ssid', 'wirelessfun') -%}
              notify.mobile_app_iphone
        {% else %}
              notify.ios
        {% endif %}
        message: Person Detected at the Front Door.
          image: >-
            /api/nest/event_media/{{ trigger.event.data.device_id }}/{{ trigger.event.data.nest_event_id }}/thumbnail
	    response_variable: thumbnail
        prompt: "Very briefly describe what you see in this image from my doorbell camera. Your message needs to be short enough to fit in a phone notification. Do not describe stationary objects or buildings."
        image_filename: {{ thumbnail}}
        media_player_entity_id: media_player.google_mini
        cache: false
    - variables:
        content: "{{ content}}"
    - stop: end
  mode: queued
@tronikos I have no idea, how you coded the integration, but I wonder, if it would be possible to specify the endpoint for the integration manually? It seems, european endpoint blocks the integration at the moment, but US one should work: python - Google Generative AI API error: "User location is not supported for the API use." - Stack Overflow
