I’ve been stumbling through a hass.io setup and am getting closer but have been trying to get MQTT to work correctly for a couple hours now and can’t seem to figure it out. Any assistance would be greatly appreciated! I think the only problem I’m having now is an inability to figure out how to set up MQTT switches
I’ve installed hass.io, and I’m trying to get Home Assistant to play with my SmartThings hub.
I installed Mosquitto, SmartThings MQTT Bridge, and the necessary SmartThings Smart App and Device.
I think all of the configuration is sound. I refreshed to clear the log in SmartThingsBridge, and here’s what is shows:
starting version 3.2.2
info: Starting SmartThings MQTT Bridge - v1.3.4
info: Loading configuration
info: Loading previous state
info: Perfoming configuration migration
info: Saving current state
info: Connecting to MQTT at mqtt://172.17.0.1:1883
info: Configuring autosave
info: Configuring API
info: Listening at http://localhost:2080
When I press a button in the SmartThings app to turn off a light called Reading Light, I see this in the SmartThingsBridge log:
info: Incoming message from MQTT: smartthings/Reading Light/switch/cmd = OFF
info: Incoming message from SmartThings: smartthings/Reading Light/switch/state = off
When I switch it back on again, there is only the message from SmartThings not from MQTT:
info: Incoming message from SmartThings: smartthings/Reading Light/switch/state = on
My problem is, I can’t seem to figure out how to configure my switches. I’ve tried an awful lot of variations, this is what I’m currently on:
switch:
- platform: mqtt
command_topic: "smartthings/Reading Light/switch/state/set"
state_topic: "smartthings/Reading Light/switch/state"
qos: 1
payload_: "on"
payload_off: "off"
retain: true
How do I figure out what the command_topic and state_topic are? I’ve tried all kinds of variations, from switch/cmd to switch/state to switch/ to switch/state/cmd, I just don’t know how we’re supposed to figure these out?
No matter what i’ve tried, the light does not respond when I press the switch in the HA dashboard, and the switch in the HA dashboard does not respond when I press the switch by other means.
Am I missing something obvious? I’ve tried a lot of searching but can’t seem to figure out what I’m doing wrong here.
In case it’s important, here’s my mqtt config:
mqtt:
broker: core-mosquitto
port: 1883
client_id: hassio
keepalive: 60
discovery: true
discovery_prefix: smartthings
Discovery doesn’t seem to work for me, at least it isn’t righting to any config files that I can tell.
Thanks in advance!
