1mfaasj
(Bowa)
February 9, 2024, 7:53am
1
I’ve got a couple of esp32 devices added into my esphome dashboard.
I’m curious if its possible to add some general sensor information to each one of them? So I’m able to send it to Home Assistant and use it there.
Like: temperature of the esp32 device, RSSI, free memory and cpu for instance?
maybe also the uptime and if there’s an update available?
Troon
(Troon)
February 9, 2024, 9:06am
2
RTM:
The device won’t know if there’s an ESPHome update available, but there are general update sensors for HA.
CaptTom
(Tom)
February 9, 2024, 12:34pm
4
As an example, I add the following at the bottom of all my ESPHome .yaml files:
# WiFi sensor
- platform: wifi_signal
name: "Device WiFi Signal dBm"
update_interval: 5.0min
entity_category: "diagnostic"
internal: true
# Reports the WiFi signal strength in %
- platform: copy
name: "Device WiFi Signal"
source_id: device_wifi_signal_dbm
unit_of_measurement: '%'
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
# Retrieve ESPHome version information
text_sensor:
- platform: version
name: "Device ESPHome Version"
internal: true
icon: 'mdi:chevron-right'
koying
(Chris B)
February 9, 2024, 2:31pm
5
My generic stuff
button:
- platform: restart
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO00
inverted: true
mode:
input: true
pullup: true
icon: mdi:memory
lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
unit_of_measurement: 'kB'
state_class: measurement
- platform: uptime
- platform: internal_temperature
name: "Internal Temperature"
text_sensor:
- platform: wifi_info
ip_address:
