General SSL failure during compiling (ESPHome:Dev in Docker) *SOLVED*
Hi all,
24 hours ago I started to get the below error when compiling. Like many users I have DNS filtering and as such this looks like the compile process is calling out to Google Analytics which seems to fail on lookup. I run ESPHome:Dev in a docker container on a Synology NAS, so no direct connection to my Home Assistant installation (Currently on a Pi4).
Should I be posting this on a more Dev oriented forum? EDIT: Reported via the Dev discord channel and being resolved. Nothing to do with DNS either… :wink:
Note: Deploying the container on the main ESPHome:Latest image works fine, so no immediate issue.
Note: I’ve blocked out my HA URL and part of the thumbprint for security reasons. Equally, not sure how ESPHome gets this since it’s running separate from the HA installation (ie. not the ingress version)
Also just noted the lower down warning referencing linux.x86_64 My nas is not x86 based…
I’ve been running the dev version for over a year with watchtower doing the container updates nearly every night without any issues. No config changes on my side, or in Docker.
Looks like this is being resolved via a PR https://github.com/esphome/esphome/pull/2370
Thanks @OttoWinter
