Hi there,
i dont know if i am at the right place to as this, but i try:
i have a running home Assistant instance here with some users from our home. They all get rekognized if home or not via fritzbox integration. It works perfectly fine.
is there any way to (automatically) generate statistics like how long was someone at home in the last month for example?
However it relies on looking up data in the recorder to calculate the sensor values and the default recorder data retention is 10 days. So if you want to measure over a longer time period than that then you have to adjust it (purge_keep_days).
