Generates list with template
Is there a way to dynamically generate a list in a yaml file using Jinja?
For example if I have a script like this:
test_script:
  fields:
    var1:
      default: false
    var2:
      default: false
    var3:
      default: false
  sequence:
    - service: notify.my_mail
        title: "Testing"
          images:
            - /config/www/pic1.jpg
            - /config/www/pic2.jpg
            - /config/www/pic3.jpg
As you can see the smtp notify service requires a list for the “images” field. I thought I could do something like this if I want to use the input parameters to control which of the 3 pictures should be included:
          images: >
            {% if var1 == true %}
            {% endif %}
            {% if var2 == true %}
            {% endif %}
            {% if var3 == true %}
            {% endif %}
While the output looks exactly what I want, HA treats the entire output of the template as one single string, and therefore does not see the dashes as list items.
I also tried to template just the filename and leave the dash outside of the template:
          images:
            - {{ 'pic1.jpg' if var1 == true else '' }}
            - {{ 'pic2.jpg' if var2 == true else '' }}
            - {{ 'pic3.jpg' if var3 == true else '' }}
However the smtp service would abort as soon as it see an empty list item.
The best I could come up with is to substitute the real image with a blank one like this:
          images:
            - /config/www/{{ 'pic1' if var1 == true else 'blank' }}.jpg
            - /config/www/{{ 'pic2' if var2 == true else 'blank' }}.jpg
            - /config/www/{{ 'pic3' if var3 == true else 'blank' }}.jpg
Is there a better way?
You could try to see if a list works. If this does work, then templating it should be relatively easy:
test_script:
  fields:
    var1:
      default: false
    var2:
      default: false
    var3:
      default: false
  sequence:
        title: "Testing"
          images: ['/config/www/pic1.jpg', '/config/www/pic2.jpg', '/config/www/pic3.jpg']
Try like this
images: >
  {% set my_list = [] %}
  {% if var1 %}
    {% set my_list = my_list + ['/config/www/pic1.jpg'] %}
  {% endif %}
  {% if var2 %}
    {% set my_list = my_list + ['/config/www/pic2.jpg'] %}
  {% endif %}
  {% if var3 %}
    {% set my_list = my_list + ['/config/www/pic3.jpg'] %}
  {% endif %}
  {{ my_list }}
Or:
images: >
  {% set mapping = {
                     'pic1.jpg': var1,
                     'pic2.jpg': var2,
                     'pic3.jpg': var3
  {{ mapping.items()
      | selectattr('1')
      | map(attribute='0')
      | map('regex_replace', '^', '/config/www/')
      | list
Thanks! Didn’t know that you can use the square bracket instead. :stuck_out_tongue:
I rewrote the script to look something like this and it works! The smtp service just ignore all the extra commas when some of the variables are false.
images: >
  [ {{ '/config/www/pic1.jpg' if var1 == true }},
    {{ '/config/www/pic2.jpg' if var2 == true }},
    {{ '/config/www/pic3.jpg' if var3 == true }} ]
Thank TheFes! Those are much nicer than the one I came up with. I ended up using the 2nd one you suggested.
