Hello to all,
I’m working an a generic configuration regarding four modbus devices on the same modbus.
My idea/goal is to have one generic description of the modbus devices and that I can use it multiple times. I’m almost there but I’m overlooking something that’s making me stuck. Who can help me further?
The file base.energy-meters.yaml is the main file of the config and is including .base.meter.yaml four times. The problem I’m phasing is that only the first part of
- platform: modbus_controller is added to the generated output. In summary: only address: 0 is added to the generated output and address: 2 and address: 4 are not.
See the source config and generated output below.
esphome:
friendly_name: energy-meters
esp32:
board: m5stack-atom
framework:
type: esp-idf
version: recommended
<<: !include .base.yaml
# Uart interface definition
uart:
tx_pin: GPIO26
rx_pin: GPIO32
# baud_rate: 115200
baud_rate: 38400
parity: EVEN
# Modbus interface definition
modbus:
uart_id: uart_energy_meters
#send_wait_time: 500ms
substitutions:
first: pv
second: heat_pump_outside
third: heat_pump_inside
fourth: ev
# Modbus devices definition
modbus_controller:
- id: ${first}
address: 1
modbus_id: modbus_energy_meters
setup_priority: -10
update_interval: 5s
- id: ${second}
address: 2
setup_priority: -10
update_interval: 5s
- id: ${third}
address: 3
setup_priority: -10
update_interval: 5s
- id: ${fourth}
address: 4
setup_priority: -10
update_interval: 5s
- <<: !include { file: .base.meter.yaml, vars: { device_name: "${first}" } }
- <<: !include { file: .base.meter.yaml, vars: { device_name: "${second}" } }
- <<: !include { file: .base.meter.yaml, vars: { device_name: "${third}" } }
- <<: !include { file: .base.meter.yaml, vars: { device_name: "${fourth}" } }
.base.meter.yaml
modbus_controller_id: ${device_name}
<<: &volts_sensor
address: 0
register_type: read
value_type: FP32
unit_of_measurement: V
device_class: voltage
state_class: measurement
<<: *volts_sensor
address: 2
modbus_controller_id: pv
<<: *volts_sensor
address: 4
Generated output:
INFO Reading configuration /config/esphome/base.energy-meters.yaml...
INFO Configuration is valid!
substitutions:
first: pv
fourth: ev
esphome:
build_path: .esphome/build/energy-meters
platformio_options: {}
includes: []
libraries: []
name_add_mac_suffix: false
min_version: 2023.3.2
esp32:
board: m5stack-atom
framework:
version: 4.4.4
sdkconfig_options: {}
advanced:
ignore_efuse_mac_crc: false
components: []
source: ~3.40404.0
platform_version: platformio/espressif32 @ 5.3.0
type: esp-idf
variant: ESP32
uart:
- id: uart_energy_meters
tx_pin:
number: 26
mode:
output: true
input: false
open_drain: false
pullup: false
pulldown: false
inverted: false
drive_strength: 20.0
rx_pin:
number: 32
mode:
input: true
output: false
open_drain: false
pullup: false
pulldown: false
inverted: false
baud_rate: 38400
parity: EVEN
rx_buffer_size: 256
stop_bits: 1
data_bits: 8
modbus:
- uart_id: uart_energy_meters
send_wait_time: 250ms
disable_crc: false
modbus_controller:
- id: pv
address: 0x01
setup_priority: -10.0
update_interval: 5s
command_throttle: 0ms
- id: heat_pump_outside
address: 0x02
update_interval: 5s
- id: heat_pump_inside
address: 0x03
update_interval: 5s
- id: ev
address: 0x04
update_interval: 5s
address: 0
register_type: read
value_type: FP32
disabled_by_default: false
force_update: false
bitmask: 0xFFFFFFFF
skip_updates: 0
force_new_range: false
response_size: 0
register_count: 0
modbus_controller_id: heat_pump_outside
address: 0
register_type: read
value_type: FP32
force_update: false
bitmask: 0xFFFFFFFF
skip_updates: 0
response_size: 0
register_count: 0
modbus_controller_id: heat_pump_inside
address: 0
register_type: read
value_type: FP32
force_update: false
bitmask: 0xFFFFFFFF
skip_updates: 0
response_size: 0
register_count: 0
modbus_controller_id: ev
address: 0
register_type: read
value_type: FP32
force_update: false
bitmask: 0xFFFFFFFF
skip_updates: 0
response_size: 0
register_count: 0
wifi:
domain: .local
reboot_timeout: 15min
power_save_mode: LIGHT
fast_connect: false
enable_btm: false
enable_rrm: false
networks:
- ssid: !secret 'wifi_ssid'
password: !secret 'wifi_password'
priority: 0.0
use_address: energy-meters.local
logger:
baud_rate: 0
tx_buffer_size: 512
deassert_rts_dtr: false
hardware_uart: UART0
level: DEBUG
logs: {}
api:
encryption:
key: !secret 'api'
port: 6053
password: ''
ota:
password: !secret 'ota'
safe_mode: true
port: 3232
reboot_timeout: 5min
num_attempts: 10
