should i be able to update HA from the hassio built in update using the generic linux install? I get this error when i press the button
20-01-24 02:15:39 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.104.3
20-01-24 02:15:39 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.103.6 to homeassistant/qemux86-64-homeassistant:0.104.3
20-01-24 02:15:39 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.104.3.
20-01-24 02:16:14 ERROR (SyncWorker_3) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.104.3 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.104.3: No such image: homeassistant/qemux86-64-homeassistant:0.104.3”).
20-01-24 02:16:14 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
