I want to use the generic thermostat. but don’t want directly use the heater as target device.
I tried to use a input boolean but that does not work
anyone know how to make a virtual toggle device?
not working for me.
the swtich does not stay on and also the thermostat does not accept this.
Not sure if this helps at all, but I coded an eco-bee style thermostat to receive input from a couple motion/temp sensors and output commands to an air conditioner unit. You could add heater functionality (I’ll be adding this as soon as I purchase some IR space heaters for my apartment).
Virtual command switch is working
use /bin/true as command
