I’ve set up the Generic Thermostat. It shows up perfectly in my dashboard.
I run my wall mounted AC through the IR Blaster on my SwitcBot Hub 2. It works fine both with the buttons on the hub or through the Switchbot app.
Unfortunately, the AC is never activated because there’s a proplem with the toggle switch.
Watchman finds the following:
-== Missing 4 entity(ies) from 20 found in your config:
| Entity ID | State | Location |
| automation.alarm_sound | missing | scripts.yaml:19 |
| switch.a_c | unknown | configuration.yaml:14 |
| switch.heat | unknown | configuration.yaml:33 |
| alarm_control_panel.alarm | missing | custom_components/alarmo/services.yaml:5,44
Here’s the entry from configuration.yaml
climate:
- platform: generic_thermostat
heater: switch.a_c
target_sensor: sensor.indoor_outdoor_meter_632c
min_temp: 15
max_temp: 25
ac_mode: true
target_temp: 24
cold_tolerance: 0
hot_tolerance: 1
min_cycle_duration:
seconds: 300
initial_hvac_mode: "off"
home_temp: 23
away_temp: 25
sleep_temp: 25
precision: 0.1
target_temp_step: 0.5
In my entities, switch.a_c shows up under SwitchBot Cloud.
Am I missing something obvious?
