I’ve created a generic_thermostat to control my “dumb” air conditioner using a Zigbee2MQTT IR Blaster. My idea was to create an automation to send a IR command for each change in the thermostat (on, off, each target temperature).
Turning on and off works fine, but changing the target temperature is not triggering the automation, nor it shows in my logbook.
Here’s the configuration.yaml for the thermostat:
climate:
- platform: generic_thermostat
name: Living Room AC
unique_id: climate.living_room_ac_ir
heater: switch.living_room_ac
target_sensor: sensor.front_door_device_temperature
min_temp: 18
max_temp: 25
ac_mode: true
target_temp: 19
cold_tolerance: 3
hot_tolerance: 3
min_cycle_duration:
seconds: 5
initial_hvac_mode: "off"
precision: 1
The automation is a bit long as I used several triggers, but it is as follows.
alias: IR - Living Room Air Conditioner
description: ""
- platform: state
entity_id:
- climate.living_room_ac_ir
to: cool
- platform: state
entity_id:
to: "off"
- platform: state
entity_id:
attribute: temperature
to: "18"
- platform: state
entity_id:
to: "19"
- platform: state
entity_id:
to: "20"
- platform: state
entity_id:
to: "21"
- platform: state
entity_id:
to: "22"
- platform: state
entity_id:
to: "23"
- platform: state
entity_id:
to: "24"
- platform: state
entity_id:
to: "25"
condition: []
- if:
- condition: trigger
id:
- turn_on
then:
- service: mqtt.publish
qos: 0
retain: false
topic: zigbee2mqtt/Linving Room IR Blaster/set
payload: >-
{"ir_code_to_send":
"AAAAAAA"}
- if:
id:
- turn_off
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"BBBBBB"}
- if:
id:
- temp_18
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"CCCCCCC"}
- if:
id:
- temp_19
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"DDDDDD"}
- if:
id:
- temp_20
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"EEEEEEE"}
- if:
id:
- temp_21
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"FFFFFF"}
- if:
id:
- temp_22
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"GGGGGG"}
- if:
id:
- temp_23
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"HHHHHH"}
- if:
id:
- temp_24
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"IIIIIII"}
- if:
id:
- temp_25
then:
qos: 0
retain: false
payload: >-
{"ir_code_to_send":
"JJJJJJJ"}
mode: single
Thank you in advance!
