Hi all,
I am a bit mystified on how to get this thing working - I feel like I have tried everything. Essentially: nothing I do will trigger the switch. Not moving the target termperature, not turning the away mode on and off, and (of course) not setting the target temp to a value higher than the sensor.
And so I come to you, cap in hand, asking for help
I have Google Home successfully changing the thermostat target value so I am very much looking forward to getting this going.
The primary thing that I am suspicious of: the temperature sensor values are correctly logged in the ‘state history’ (not in my screenshot as I had jjust rebooted), but not displayed as ‘Currently: nn°’ as I have seen in others’ posts - indicating that the component is not detectig the sensor?
P.S. maybe this has been placed in the ‘too hard basket’?
OK I will just bulletpoint the things I anticipate being asked by any helpful people:
- The switch works when manually triggered
- The switch successfully calls using switch.toggle
- The switch is an mqtt switch controlling a Sonoff Basic
- I have set the state to ‘heat’ and away mode is off
- The state of the sensor is a float value, with 1 decimal place
- My previous automation based on the sensor worked very reliably
- I have tried the other optional config items for generic_thermostat
- I created a dummy sensor that read off an input_number - no change
- Anything else please ask I will be very grateful for the help!
configuration.yaml:
climate:
- platform: generic_thermostat
heater: switch.lounge_heater
target_sensor: sensor.temp
min_temp: 10
max_temp: 22
ac_mode : 'False'
target_temp: 18
cold_tolerance: 0.3
hot_tolerance: 0.3
away_temp: 11
Switch.yaml:
- platform: mqtt
state_topic: "stat/heater/POWER"
command_topic: "cmnd/heater/POWER"
availability_topic: "tele/heater/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
payload_available: "Online"
payload_not_available: "Offline"
Sensor:
- platform: mqtt
state_topic: "tele/dooralarm/SENSOR"
value_template: "{{((value_json['SI7021'].Temperature) | round(1)) | float }}"
qos: 1
json_attributes:
- Temperature
