Dealing with zone valves for radiant heating:
I realize generic thermostat cannot switch two entities on, so I set up a group:
living_room_heater:
entities:
- switch.relay_channel_2
- switch.relay_channel_3
Then set it up like this:
climate:
- platform: generic_thermostat
name: Family room (downstairs)
heater:
group: living_room_heater
target_sensor: sensor.lumi_lumi_weather_12114a04_temperature
min_temp: 65
max_temp: 75
hot_tolerance: 0.5
ac_mode: false
initial_hvac_mode: heat
So when I check config before restart, I get this :
Invalid config for [climate.generic_thermostat]: value should be a string for dictionary value @ data[‘heater’]. Got OrderedDict([(‘group’, ‘living_room_heater’)]). (See ?, line ?).
Invalid config for [climate.generic_thermostat]: string value is None for dictionary value @ data[‘name’]. Got None. (See ?, line ?)
At a loss, it worked previously…
