I wonder if someone here can offer some clarity on the configuration of the thermostat… It seems like it should be a very small config change, but I can’t seem to find the answer I need.
The situation is very simple, I added a couple of thermostats (Centralite Pearl Thermostat using zigbee if anyone is interested) and Home Assistant connects and operates them almost perfectly out of the box. The tiny issue I have, is there doesn’t seem to be a way of modifying the global (default) ‘hot_tolerance’ or ‘precision’ values without creating different zones separately in a config file, which seems completely unnecessary given that everything else for the most part is satisfactory.
Anyone know if this is possible?
version 2022.2.9
RZ
