Generic Thermostat - Define variable as "away_temp"
I would like to define a variable as “away_temp” based on the “temperature” attribute of the climate.
The idea is, if I set XX degrees on the climate, I want 2 degrees less when I leave my home (triggered when my “home” entity switch from on to off).
I though about something like this:
- platform: generic_thermostat
  heater: light.qubino_goap_zmnhjd1_flush_dimmer_pilot_wire_level_3
  target_sensor: sensor.fibaro_system_fgsd002_smoke_sensor_temperature_4
  min_temp: 15
  max_temp: 30
  away_temp: 18.5    <<<< I would like to replace by "away_temp: {{ state_attr('climate.desk','temperature') - 2 }}"
But right now it’s not possible. On my logs, I have the error message below:
2020-10-29 17:26:34 ERROR (MainThread) [homeassistant.components.homeassistant] Invalid config for [climate.generic_thermostat]: expected float for dictionary value @ data['away_temp']. Got "{{ state_attr('climate.desk','temperature') - 2 }}". (See ?, line ?).
Did you find a solution? Looking for the same. :slight_smile:
Hi. Any progress? I’m looking for something similar. I want to set temperature from helper for more multiple thermostats
