Hello world,
i have a problem with a generic thermostat: my plan is a frontend thermostat that can control a conditioner by an IR signal (it’s a temporary solution…)
Using directly service “remote.send_command” create some problems with the frontend, so I decided tu create an input_boolean to trig an automation. I try also to use other solution, but the automation does’nt work …)
Climate heater → ON/OFF → trig automation → script to send IR command (this script works fine)
climate:
- platform: generic_thermostat
heater: input_boolean.condizionatoreX #(I try also wit a generic switch...)
target_sensor: sensor.soggiorno
ac_mode: true
min_temp: 21
max_temp: 27
cold_tolerance: 0.3
initial_hvac_mode: "cool"
AUTOMATION
- alias: Clima HI
- platform: state
entity_id:
- input_boolean.condizionatoreX #(I try also wit a generic switch...)
to: 'On'
condition:
- condition: time
after: '09:00:00'
before: '23:30:00'
- service: script.clima_on_hi
mode: single
The frontend thermostat seems to work fine, but no signals are send… I did some attempts and I think that it’s an automation problem. Where il the bug??
