@123
This is a very nice solution. I plan on taking what you have done here and use it for a video where I’m taking a Sonoff SV and building a humidifier control. IE I’m going to flip the ON and OFF command so the device powers when the humidity is low and make new names, but your elegant code will remain.
I’ll credit you and put a link to it here in this post.
Thanks for supporting the more programming-addled among us!
https://youtu.be/2bRu4H6qo84
Here is the link to my YouTube video where I use this automation to sucessfully make my Humidistat solution to work!
Could you please share again your automations? Many thanks
Here you go: Ubuntu Pastebin
Card is updated too:
card_mod:
class: top-level-card
entities:
- entity: switch.lounge_dehumidifier
state_color: true
- entity: script.lounge_dehumidifier_emptied
state_color: true
- animation:
state: 'off'
columns: '1'
direction: right
entities:
- entity: sensor.lounge_dehumidifier_power
max: '800'
min: '0'
severity:
- color: '#039BE5'
to: '299.9'
- color: '#0da035'
to: '899.9'
- color: '#e0b400'
to: '1799.9'
- color: '#e45e65'
to: '2400'
entity_row: true
height: 28px
positions:
icon: inside
indicator: inside
minmax: 'off'
title: 'off'
value: inside
type: 'custom:bar-card'
value_style:
color: var(--primary-text-color)
text-shadow: none
- card_type: 'custom:fold-entity-row'
entities:
- entity: automation.lounge_dehumidifier_direct_automation
state_color: true
- entity: automation.lounge_dehumidifier_re_enable
state_color: true
- entity: input_number.lounge_dehumidifier_condensation_set
- entity: input_number.lounge_dehumidifier_outside_temp_set
head:
label: Direct Automation
type: section
padding: 0
type: 'custom:hui-element'
entities:
- entity: automation.lounge_dehumidifier_forecast_automation
state_color: true
- entity: input_datetime.lounge_dehumidifier_run_time
- entity: input_number.lounge_dehumidifier_rh_set
- entity: input_number.lounge_dehumidifier_forecast_temp_set
head:
label: Forecast Automation
type: section
padding: 0
entities:
- entity: input_boolean.lounge_dehumidifier_mute_for_movie
state_color: true
- entity: input_number.lounge_dehumidifier_run_time
head:
label: Common Configuration
type: section
padding: 0
show_header_toggle: false
title: Lounge Dehumidifier
type: entities
It won’t be this way for long. I plan to put an ESP32 in the dehumidifier for direct control and monitoring soon.
Hi i run ESPhome (not tasmota) and i use a relay to switch on and off the humidifier(not dehumidifier). My automation script is not working, can you help me with that? The humidifier needs to turn on when the dht11 sensor reads 45% or lower, and turn off if it reaches more then 52% humidity. For sanity check i need to paste this to the automation.yaml or create a new custom component and a new humidifier.yaml file?
The script:
- id: '*************'
alias: Humidifier on
description: ''
- platform: time_pattern
minutes: 5
condition:
- condition: numeric_state
entity_id: sensor.humidity
above: '45'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
after: '10:00'
before: '20:00'
- condition: state
entity_id: switch.relay_humidifier
state: 'off'
- type: turn_on
device_id: *************
domain: switch
mode: single
alias: Humidifier off
description: ''
minutes: 5
condition:
above: '52'
- condition: time
after: '10:00'
weekday:
- mon
- tue
- wed
- thu
- fri
before: '20:00'
- condition: state
state: 'on'
- type: turn_off
device_id: ********************
domain: switch
mode: single
It turns on and off every 5 minutes… i tested it with 10sec intervals because i didn’t have the time to sit and watch it that long. It works between the two values great but outside of the two value things are different.
