I’m new to Home Assistant (coming from OpenHAB) and I hope I’m in the right section of the Forum here.
I have a dehumidifier running on an MQTT power plug with a humidity sensor on it. The machine should e.g. turn on when the humidity is over 60%, and turn off when it has reached 50% (mean value is 55%).
This works perfectly with the generic_thermostat, but as the name sais, it’s designed for temperature and not for humidity. It always shows “°C” instead of “%”, even if I set “unit_of_measurement: ‘%’”, and says “Heat” when the dehumidifier turns on.
Is there an easy way to customize the generic_thermostat so I can see the percentage and maybe change the word “Heat” to something else? Or is there something similar to the generic_thermostat for humidity? It’s important for me to have an easy way to control the target humidity via the interface without changing any code as some non-technically versed people will also use this (it doesn’t have to be a fancy circle, +/- buttons would also be okay)
I created an input_number with the name schieber_steckdose1 and put the following code into my automations.yaml, restarted hass.io, but nothing happens when I move the input_number… any ideas?
Btw, I created two rules - one for “ON”, the other for “OFF” - is it possible to combine these rules into one rule?
Good! Glad to hear using the Template Editor helped you solve the problem.
Going forward, you should learn how to format your code for presentation on this forum. YAML indenting is critical and, in the way your code is shown, it is difficult to interpret it correctly.
Simply enter three consecutive backquotes ``` on a separate line before your code and then another set of three backquotes, on their own line, after your code. This will instruct the forum’s software to display your code in a formatted appearance (and make it easier for others to read it).
Yes, it’s possible to combine the two automations into one.
Thanks, but it only works with the “tolerance” of + 2.5, but not with - 2.5
As I wrot in my first post: The machine should e.g. turn on when the humidity is over 60%, and turn off when it has reached 50% (mean value is 55%) --> so the input_number.schieber_steckdose1 would be 55 in this example
I followed what you posted in your secondexample which uses +2.5 for both turning the switch on and off.
I now see that in your first example, you used +2.5 for on and -2.5 for off.
Do you want help to fix the automation or do you feel ready to handle it yourself?
BTW, I’m confused by the example you provided. Doesn’t it represent a range of +/- 5? If you set the target to 55 it turns the dehumidifier on at 60 (target+5) and turns it off at 50 (target-5). The humidity can then rise up to 60 again until the dehumidifer is turned on.
Sorry for confusing you - I was also a little confused at the beginning, but finally found the right automation which is described in this comment.
The rule behind it: If I set the target to 55%, the dehumidifer turns on when humidity gets over 57.5% and turns off when it reaches 52.5%
In OpenHAB, I was able to just put two if-conditions into one rule, which would look like somthing familiar to the following automation in HomeAssistant, but this doesn’t work:
LO D HI
OFF | CURRENT | ON
OFF>>>>>>>>>>>>>>>>>>>>|
|<<<<<<<<<<<<<<<<<<<<<<ON
There are three operating states:
OFF: Ambient humidity is less than LO so the dehumidifier is set to off.
ON: Ambient humidity is greater than HI so the dehumidifier is set to on.
CURRENT: Ambient humidity is within the range set by LO and HI. The off and on states overlap within the range (it can be either onoroff within this range). It depends on whether the dehumidifier is currently on and decreasing the humidity from HI to LO, or if the dehumidifier is off and allowing humidity to rise from LO to HI.
Here’s an example:
Desired humidity is 55 so LO=53.5 and HI=57.5
Ambient humidity is 57.
Dehumidifier is off.
Humidity rises to 58 and triggers the automation.
Humidity now exceeds HI so the dehumidifier will be set to on.
Humidity falls to 57 and triggers the automation. Humidity is less than HI but more than LO. The dehumidifier is set to its CURRENT state which is on (the automation is obliged to assign a value to service_template) .
Humidity falls to 56 and triggers the automation. It is still within range and the humidifier is set to its CURRENT state. This pattern repeats until the humidity reaches the LO threshold.
Humidity falls to 53 and triggers the automation. It is now less than LO so the dehumidifier is set to off.
Humidity rises to 54 and triggers the automation. It is now higher than LO but less then HI. The dehumidifier is set to its CURRENT state which is off. This behavior continues until humidity exceeds HI and then the dehumidifier is set to on.
The following automation implements the behavior I just described. It is triggered either by changes to the sensor or to the input_number. It computes LO and HI thresholds and then determines if the humidity is below, within, or above the range. Depending on the result, it will call the correct service.
If humidity < LO then call switch.turn_off
If humidity > HI then call switch.turn_on
If humidity is between LO and HI then call the service corresponding to the dehumidifier’s CURRENT state.
- id: steckdose1_luftfeuchtigkeit
alias: 'Steckdose 1 Luftfeuchtigkeit'
platform: state
entity_id:
- input_number.schieber_steckdose1
- sensor.steckdose1_am2301_humidity
service_template: >-
{% set hi = (states('input_number.schieber_steckdose1') | float) + 2.5 %}
{% set lo = hi - 5 %}
{% set humidity = states('sensor.steckdose1_am2301_humidity') | float %}
{% if humidity > hi %}
switch.turn_on
{% elif humidity < lo %}
switch.turn_off
{% else %}
switch.turn_{{states('switch.steckdose1') | lower}}
{% endif %}
entity_id: switch.steckdose1
You may wish to consider tagging the post as ‘solution’ so others can find it more easily.
I used openHAB for about a half-year then looked into Home Assistant to see how it differs. I found it more to my liking (but both are equally competent products with helpful communities).
You’ll find Home Assistant’s automations, with their YAML structure and Jinja2 templating, to be quite different from openHAB’s Rules DSL. I encourage you to review the examples in the Cookbook to become more comfortable with this different style of creating automation logic. There are more complex examples found throughout this forum as well as in the Github repos shared by Home Assistant users.
You are right, it’s really different.
For me personally, the rules in OpenHAB were just easier to understand and implement, but seriously, this is the only thing that I am missing about OpenHAB when I compare it with Home Assistant.
