Hi Guys -
Came across Generic Thermostat in Home Assistant and trying to set up. My requirement is simple.
Set the target temperature to 78 with a hot_tolerance of 4 degrees. Set the ac_mode to ‘true’
I’m stumped as to how to set up the heater : “switch” entity. I’ve entered my thermostat entity directly into the heater and I believe that’s not accurate. The documentation says that is should be a toggle. But I’m able to follow what that means.
Here is my config. Any insights are truly appreciated.
